Best way to clean the old BBQ grates!
Discussion in 'The Smokehouse' started by don2222, Jun 11, 2022.
  1. don2222
    don2222
    Salem NH
    Hello
    I have been trying for years to find a fairly easy way to clean these nasty dirty grates!
    Scrubing with grill brushes, wire wheels etc.
    Then blasting with the decent DeWalt 15 gallon compressor but No Cigar! Very frustrating! So finally I got a Quincy but the blasting cabinet with aluminum oxide was too much and took a lot of the finish off!
    So finally I took out the harbor freight soda blaster and the first time I used it with the old DeWalt it kept clogging. Just like many reviews of this nice blue portable soda blaster people were disappointed with the clogging.
    This time I was ready with the right stuff! I fired up the Quincy and turned on the Chilla! ( i.e Quincy Refrigerant Air Dryer ) This makes the compressed air stone cold and bone dry!
    Then with the right media setting @ 60 PSI it was snowing like Christmas!! Amazing!
    Cleaned the grates right up without removing the finish coating!
    The Air Chief with brass wire wheel which is a little less abrasive than the shinny steel wire wheel works great on the back side grooves to get the nasty hardened black soot off too!
    Anyone try this?
  2. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    hey man...not for nuthin but if you keep your grates clean like you should(like scrubbin yer ballz) no need for blasting....remember protein sticks to protein
    Softwood and The Wood Wolverine like this.
  3. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    i use a pressure washer.....not on my ballz
    Softwood, huskihl, eatonpcat and 2 others like this.
  4. Camber
    Camber
    Montana
    Never used a soda blaster on my grills, but never clean them ever. I like it when my elk steaks come off the grill heavier than they went in.
  5. eatonpcat
    Why not??
  6. jrider
    jrider
    Get a good grease fire going. That will clean em up good enough.
  7. Greenstick
    Greenstick
    If the grates get kinda gross I just take them off and give them a spray with oven cleaner, let set a while, then blast with a hose. Might do it a couple times if there is any really stubborn stuff but it seems to work well and not much effort.
    don2222 likes this.
  8. MikeInMa
    A weed burner/torch gets my grates clean.
    A minute or two under fire, then a stiff brush. Good to go.
  9. don2222
    don2222
    Salem NH
    Harbor Freight makes a good one?
    Greenstick and MikeInMa like this.
  10. saskwoodburner
    saskwoodburner
    Whatever carbon or crud that remains on my grates gets purified/exorcised when the grill hits 550-600 F. Then it falls right off with a quick scrape.
    JD Guy and MikeInMa like this.
  11. MikeInMa
    It might be ok. I have no experience with that one.
  12. buzz-saw
    buzz-saw
    Ct.
    Hmmmm, I didn't know they made anything good.:whistle::rofl: :lol:
