Battery Station for Pellet Stove
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by IHATEPROPANE, Dec 30, 2022.
  1. IHATEPROPANE
    IHATEPROPANE
    I have a UPS that will run my stove for about 90min. Allows for me to shut it down or get the genny running assuming I am home.
    Been thinking about getting one of those pure sine battery packs/solar generators that could run it through the night so I could avoid having my genny out in the open.
    Stove uses about 600watts over 8 hours so I would get one about that size.
    Any thoughts, experiences with these?
  2. corncob
    corncob
    Somewhere in Lower Michigan
    Interestingly, I too hate (dislike) propane but it's cheaper than pellets presently.
  3. IHATEPROPANE
    IHATEPROPANE
    $4.29 a gallon here...
    jtakeman, imacman and wildwest like this.
  4. jtakeman
    Which ups do you have?
    I bought an expandable unit where there is an option to add batteries on the back by a quick connect. I have plans to add a 24v battery bank and a solar charger with solar panels. I hate running my generator over night. Harbor frieght has solar battery controller/chargers and the solar panels.
    I'd luv to go off grid and put a chit load of solar panels in my field. Plus wind in case no sun. Run the hole shack and giv the everchit the middle deal. :D
    bogieb, JD Guy, imacman and 2 others like this.
  5. IHATEPROPANE
    IHATEPROPANE
    Don't think it's expandable. Thought about going the battery and inverter and charger or solar panel route. Thing is if I am not home my wife would never figure out the batter to inverter part...
    PelletHound, jtakeman and imacman like this.
  6. wildwest
  7. jtakeman
    Thats why I opted for the UPS to be my invertor. It will do the cycle to battery automatically
    It may be possible to use the UPS as the invertor by adding a quick disconnect to the UPS. I've seen others add more battery capacity to the non expandable ups units. Higher mah capacity to be more specific.
    imacman, PelletHound and IHATEPROPANE like this.
  8. IHATEPROPANE
    IHATEPROPANE
    Sounds outside my skill set...
    imacman, PelletHound and jtakeman like this.
  9. jtakeman
    Basically from what I've seen is they remove the internal battery and add quick connects to the red/black terminals. Poke a hole in the back or the box(add a grommet) and pass the wires through. Add an external battery pack is about all it is.
    Or go look on ebay for an expandable unit. I bought a new old stock unit cheap for my puter/tv. I had to replace the batteries as they were out dated. But the unit was brand new. I also bought one for the fish tank as well. That is the only one we bought the expanded battery for.
    imacman and IHATEPROPANE like this.
  10. corncob
    corncob
    I pre bought an extra 500 gallons at $1.69 per so I'll run that out and switch back to corn and pellets. Have 4 ton of them in the barn from last year as well as 4 ton of seed corn. The new plus 95 condensing furnace is very frugal.
    IHATEPROPANE likes this.
  11. IHATEPROPANE
    IHATEPROPANE
    That doesn't sound too bad actually.
    imacman and jtakeman like this.
  12. CleanFire
    CleanFire
    That may be a bit conservative IHP - UPS here also has 90 minute runtime, same UPS model: which means about 600w/hr.
    (calculated / batteries rated "1,000w", x .9 power factor / efficiency factor .. and .9 PF may be "generous", in the rating.).
    I would guess you will need 5k-6k of storage reserve: for an 8 hr. runtime.
  13. IHATEPROPANE
    IHATEPROPANE
    I ran mine with it hooked up to the kill a watt and it was at 0.610kwh after 8 hours.
    When it is running the ups shows 70-90 watts depending on auger turns.
    The UPS has two 9ah batteries so I figured another 600 watts or so would just cover it.
    imacman likes this.
  14. CleanFire
    CleanFire
    Cool beans. FYI, .610 kwh * 8 hrs. of desired runtime = 4.88 kwh, or 4,880 watts of reserve needed: for an 8 hour runtime.
  15. IHATEPROPANE
    IHATEPROPANE
    0.610kwh is what it consumed over 8 hours.
    imacman and stuckinthemuck like this.
  16. CleanFire
    CleanFire
    Correct. 610 watts, per hour. ( Need to multiply by the # of hours test was ran, to get the total watts consumed: during that period. )
  17. IHATEPROPANE
    IHATEPROPANE
    No, it wasn't per hour. It was for the total of 8 hours. Per hour the ups says about 80
    imacman likes this.
  18. CleanFire
    CleanFire
    I'm sorry IHP, the #'s just don't add up, to me anyways. If the Kill-a-Watt meter showed .610 kwh, that is only -per hour- (and matches the estimated runtime capacity: of the PFC1500LCD unit).
    imacman likes this.
  19. IHATEPROPANE
    IHATEPROPANE
    That is what it showed on the setting for usage over time. Used to calculate cost.
    Here are a couple pics...it's running a little high because I had to unplug the ups but you will see what I am saying.
  20. IHATEPROPANE
    IHATEPROPANE
    It's been 12 minutes and has used 0.01kwh
    stuckinthemuck and imacman like this.
