Advice needed! Job Site/Nielsen/Cannon
Discussion in 'Chainsaws and Power Equipment' started by z1ts, Dec 28, 2022.
  1. z1ts
    z1ts
    Bristol, England
    Good day to all you fine hoarders
    We find ourselves in need of a new splitter. We're not attempting to match some of the miles of stacks displayed on here, but we are trying to get ahead of ourselves by 3 years at least and need to increase our current output.
    Does anyone have any experience of these splitters?
    Petrol Engine Vertical 12T Log Splitter
    Various brands seem to be attached to this model, some of which I've included in the thread title!
    Any advise/experience or recommendations would be very gratefully received!!!!
  2. Yawner
    Yawner
    Louisiana
    On box is says 'travel time' and '29s.' If that means a cycle time of 29 seconds, it means forget it. Everything is sky high these days for a 'decent' splitter. The 25-ton Countyline one I have is now $1799. I am not aware of any 'decent' splitter (which I consider this one as the minimum in 'decency,' that you can get for less than, say, $1,200 and that's probably on sale. I do not see Tractor Supply discount their splitters much any more. Maybe $200 off. Where I live. Sad part is I paid $699 for it, on sale, (reg $899 at that time) and I think it was just five years ago.
    It depends on what you're splitting. If the budget is tight and you have easy splitting wood and no need to transport it, I'd consider an electric, they are far, far cheaper and should be more dependable versus one with a gasoline motor.
    EDIT: Oh, wait... you're in England. Not much help there.
    amateur cutter, z1ts, Horkn and 2 others like this.
  3. JB Sawman
    JB Sawman
    pennsylvania
    I do not know anything about them but if you are not working with big wood are there any distributors of a kinetic splitter (Super split) in england they are much faster and may be cheaper
  4. Chud
    Chud
    I like the how the platform is designed to increase area when in the vertical position.
  5. brenndatomu
    If that's really a 6.5 HP engine then they have really undersized the pump to have a 29 second cycle time! Even a mediocre hyd. splitter normally has a cycle time of half that.
    Edit: I looked up the manual https://shop.cannontools.co.uk/images/shop.cannontools.co.uk/prd/1637136932CT3270 user manual.pdf
    Specs show 6.5 hp 196cc engine, 3" cylinder, and a woefully undersized 2.1 GPM pump. (single stage maybe...probably actually)
    A $125 pump swap would make this thing a rocket! https://ruggedmade.com/hydraulic-log-splitter-gear-pump-2-stage-11-gpm.html
    With the 3" cylinder (stated) and 1.5" rod (assumed) at 20.4" stroke (stated) this splitter would have a cycle time of 6.3 seconds with the 2 stage pump linked above on it!
  6. The Wood Wolverine
    I'm with the majority here. I clicked on the link and saw a 29s cycle time. That is painfully slow and would frustrate me to the point of not using it. My 2 cents, keep looking!
    amateur cutter, z1ts, Chaz and 3 others like this.
  7. Horkn
    29 second cycle time? That's painfully slow. I'd pass, probably an electric model available in England that would be faster.
  8. z1ts
    z1ts
    Bristol, England
    Thank you so so much for all your helpful replies.
    If I understand the summary correctly, I need to look for a faster cycle time (?) a bigger pump (?)
    Which then brings me to a quandary..... I don't have a need for a £2500 splitter (nor can I afford it!)
    Perhaps a better way of asking the question would be: what's the best splitter I can get (UK) for sub £1k ??
    amateur cutter and Chaz like this.
  9. The Wood Wolverine
    Since most of us are in the US, that might be difficult to answer. Take-away from the post, get one with a fast cycle time.
  10. z1ts
    z1ts
    Bristol, England
    Surely there must be some cross Atlantic brands??!!
    Or Chinesium ones that ship East & West???
    Dunno, am I hoping for too much!!!!
    amateur cutter and brenndatomu like this.
  11. Chud
    Chud
    If you have big box hardware stores you should be able to find something under the 2000 pound mark, but according to what I’ve read your inflation is worse than the US. Most mass produced splitters under $2k here are around 12 second cycle times I think. I’m not in the market so I don’t read the fine print. Get the fastest cycle time you can afford. As said previously, slow splitters are impossible/painful to get ahead with.
  12. brenndatomu
    So is the splitter in question considered "affordable"?
    If so then like I said, do a very simple and cheap pump swap to make it much faster! Then the original pump could be sold to recoup some of the cost too...
  13. Barcroftb
    Barcroftb
    The Mitten
    Seems like a no brainer.
    z1ts, Horkn, amateur cutter and 2 others like this.
