Two butts a-thawing
Discussion in 'The Smokehouse' started by MikeInMa, Dec 27, 2022.
  1. MikeInMa
    I'm planning to fire up the smoker at the end of the week.
    Each about 8.5lbs.
    I'll use some cherry and apple woods. I'll forgo any hickory this time around. I've never used cherry before.
  2. The Wood Wolverine
    Apple and cherry are my 2 staples. I've never over-powered anything with them. Always bark off and never excessive amounts of smoke. I'm not sure what kinds of cherry I've had either. I know it's been 2 varieties.
  3. Eric VW
    Yep, can’t go wrong with cherry. :salute:
    Do you normally trim your butt up? :whistle:
    And do you prefer to rub your butt… with anything in particular?
  4. MikeInMa
    I'll leave the fat cap on.
    I use Emeril's Creole seasoning and brown sugar . 2parts seasoning 1 part sugar.
    Emeril's Essence Creole Seasoning
  5. Eric VW
    Excellent!
    Do you spray with ACV every hour?
    metalcuttr, T.Jeff Veal and MikeInMa like this.
  6. MikeInMa
    I don't. But once pulled, I'll mix in extra rub. Maybe I'll add a bit of ACV, then.
    metalcuttr, T.Jeff Veal and Eric VW like this.
  7. Eric VW
    Gotcha. Just something me and local friends do… every hour, spray action time.
    I used to keep my butt in the smoker til finish temp, but no more! When it’s time to wrap, goes straight in the oven to finish. Saves plenty o’ charcoal, and the Thermo bluetooth’s to the phone so I can monitor remotely.
  8. Brad from York
    Brad from York
    York PA
    Cherry is a great smoking wood and great on the butts, but I’ve noticed the bark on that one in particular has an awful smell coming out of my smoker.
  9. huskihl
    huskihl
    One of my favorites. I bet I cook 30 pork butts per year. :yes:
  10. MikeInMa
    It'll be an overnight smoke. On about 7pm. Off the next morning.
    Nothing wrong with finishing off in the oven!
  11. The Wood Wolverine
    Pellet smoker?
    I've finished off many in the oven. :thumbs:
  12. MikeInMa
    Charcoal, in a Weber Smoky Mountain. I've had it for decades. 18"
    This is the newer 18". Not much change in shape.
  13. The Wood Wolverine
    Ah. I have a Brinkman water smoker very similar to that. Ended up getting an offset stick burner that I love using.
  14. T.Jeff Veal
    Cherry gives a good taste and beautiful color. Hope you enjoy it
  15. MikeInMa
    Apple on the right, cherry left.
    All set to go
  16. MikeInMa
    Two butts a-smoking
    I'll monitor the temps and adjust the drafts as needed. Usually, after a couple of hours, it's set it and forget it.
    metalcuttr, Eric VW, Softwood and 5 others like this.
  17. MikeInMa
    Almost 11hrs in. 250⁰ at the domestic and it smells awesome.
    I'll check Internal temp in about 4hrs. I haven't even taken a peek.
  18. MikeInMa
    Dome temps were dropping so I opened up the vents fully. Temps held for about an hour. IMG_20221231_061724.jpg
    They are now wrapped in foil and in a 250⁰ oven for a few hours.
    The sections of the smoker are separated to let it cool for cleanup when it brightens up outside.
  19. T.Jeff Veal
    that's gonna be tasty
  20. Chvymn99
    X2…. Ought to make some good pulled pork…
