Artic Blast in middle GA...
Discussion in 'Everything Else (off topic)' started by T.Jeff Veal, Dec 26, 2022.
  1. T.Jeff Veal
    I had to work 7AM-7PM shift this weekend. What fun we had, especially Sunday afternoon when things thawed a bit. We found at least 7-8 places with ruptured pipes...
    At one of our bulk baggers, even
    On my end of the plant...
    And that pipe was insulated...
    This building usually has enough heat from the calciner to be fine. It has been shut down for a couple months. Probably shattered 50' of this line... 1226221507.jpg 1226221510.jpg 1226221512.jpg 1226221513.jpg
    And it blew the gate valve apart at the top of the line... 1226221513a.jpg 1226221513b.jpg
    This elbow was insulated, supplied water to my control room and other equipment I run... 1226221615.jpg
    Should be a real fun day for the maintenance dept tomorrow...
  2. clemsonfor
    Yea I'm sure those un insulated pipe were just asking for it. Was it not thought to drain those lines? Especially if it wasn't in use and we knew the cold was coming for awhile?
    I'm a little ways north of you and I believe we got down to 13f. We dipped below freezing Thursday night and nothing thawed out till today. Not sure if we got above freezing untill yesterday and it wasn't by much.
  3. JD Guy
    JD Guy
    Upstate SC
    Wow, That’s a real big ‘ol OOPS :faint:
  4. MikeInMa
    X2
  5. JimBear
    JimBear
    My daughter said they closed UGA one day because of dangerously cold temps, 10*. Lol.
    BUT if you don’t get these temps normally it can be dangerous.
  6. Smokinpiney
    Smokinpiney
    "South" Jersey
    Ughh that's no fun.
  7. eatonpcat
    Georgia insulation...sweater at most!:D:p:cool:
    That does suck Jeff
  8. Greenstick
    Greenstick
    We just broke out of the deep freeze up here in Dakotah Territory. Supposed to continue to warm through the night and by Wednesday be a high of 34°. We will be almost 55° warmer than our low a couple days ago. I can feel your pain, the cold brings out the worst in vehicles, plumbing, furnaces, and equipment.
  9. Eckie
    Eckie
    And some people.....
  10. Greenstick
    Greenstick
    Was going to include that but was being uncharacteristically nice.
  11. Backwoods Savage
    Wow! That is a real mess and I'm happy I don't have to do the repairs.
  12. Chazsbetterhalf
    Chazsbetterhalf
    How long will you they be shut down for repairs?
  13. T.Jeff Veal
    Didn't shut down, they are able to isolate the sections for repair.
  14. T.Jeff Veal
    We were lucky at home too. Walked outside this morning to feed the cats, saw water beginning to run down the hill. Did some checking. Faucet by the pool was wrapped and covered with a bucket. It just broke the wye...
  15. Stephiedoll
    Stephiedoll
    Omaha, NE.
    That's what I call a very bad day. What kind of plant is it Jeff?
  16. T.Jeff Veal
    Kaolin clay plant. We process clay for many uses. Pigment in paints, plastic and rubber industry...
  17. T.Jeff Veal
  18. The Wood Wolverine
    Holy hum. Good it was just some pipes/fittings. The damage that can occur with running liquids can be horrendous. Local guy on the news had a pipe break on his 3rd floor and it ruined pretty much the entire interior of his building. It was a sprinkler pipe and he said it ran for about 15-20 minutes till the fire dept. got there to shut it down.
