What oil/ratio you running?
Discussion in 'Chainsaws and Power Equipment' started by Rick Capper, Dec 25, 2022.
  1. Rick Capper
    Rick Capper
    Pennsylvania
    I have an old stihl 025and a stihl ms 290 that I've had forever. Currently thinking about a 620pw echo but didnt pull the trigger just yet.Countless cards cut with these 2 saws.i always ran stihl 50:1 mix with no problems.however there had been a half dozen times over the years I was out of stihl mix so I would mix up a few gallons on gas with mercury quicksilver tcw 3 outboard oil at 40:1.the saws didn't mind and still run great today.just wondering of any body else besides me has done this.oh and merry Christmas to everybody!
  2. clemsonfor
    Saw probably won't care between 50:1 and 40:1. Use good oil and you will be fine, assuming you have it tuned properly.
    I run 32:1 in all my yard stuff to include trimmers, all my saws and hedge trimmers. I run Red Armor oil which is one of the better ones, even if you run on the ragged edge of insanity. I always ran 40:1 before that. 50:1 in my opinion is an EPA thing. One year Stihl recommends 40:1 and then the next it's 50:1. They produced the same saws those years and didn't have any oil reformulations. So why the change?:loco: :crazy:
    Eggshooterist is kind of a resident expert on oil here. :whistle::yes:
  3. The Wood Wolverine
    40:1 in 'em all, ported and not. Even milling @ that ratio with excellent results as I've tore that saw down many times to check the internals for wear and residual oil.
  4. FarmerJ
    FarmerJ
    Minnesota
    Everything is setup for 50:1. Never had issues with any I’ve used it in.
  5. Chud
    Chud
  6. clay shooter
    clay shooter
    ENGLAND
  7. Ohio
    Not Ohio
    40:1 Red Armor.
  8. Eggshooterist
    Eggshooterist
    Erff
    Nope! Not getting involved.
  9. buzz-saw
    buzz-saw
    Ct.
    X2 on this
    Non ethanol fuel in everything 2 stroke.
    Just my 2 cents on a much discussed topic.
  10. Mrxlh
    Mrxlh
    Dat Boot
    X2…
  11. morningwood
    morningwood Administrator
    X2
  12. JimBear
    JimBear
    Good answer, good answer. We will be keeping our eye on you. Lol.
  13. brenndatomu
    For the average firewood hoarder, 40:1 any good grade of OPE oil...but NOT outboard oil...yeah yeah I know, you got away with it, but sooner or later that will likely bite you in the arse.
    You already are...you are subbed now...:D
  14. FarmerJ
    FarmerJ
    Minnesota
    Fraidy cat
  15. brenndatomu
  16. buZZsaw BRAD
    I run stihl 40:1 silver bottle. Years back an OPE dealer told me to run 50:1 but mix with two gallons of gas so a 40:1 ratio. I use 91 or sometimes 93 octane.
    I know a lot of guys run non E fuel, but ive never had an issue using "normal" gas for many years.
  17. Eggshooterist
    Eggshooterist
    Erff
    I'll stay subbed to watch the circus that might unfold.
  18. fox9988
    fox9988
    NW Arkansas 72717
    Cheapest oil in the cheapest gas my whole life. 40/1. Never a problem.
  19. Rick Capper
    Rick Capper
    Pennsylvania
    I put a new muffler on the 025 over this past summer.piston and cylinder look like new after 20 plus years and 100s of tanks of fuel.that outboard oil sure didn't hurt anything
  20. brenndatomu
