Always wanted to try this
Discussion in 'The Game Room' started by Eric Wanderweg, Dec 19, 2022.
  1. Eric Wanderweg
    Homemade 0.177 caliber pellets. I’m not sure what to expect, but it should be fun :) The off the shelf Daisy pellets weighed in at exactly 0.5 grams on the scale, and my CNC turned aluminum pellets came in at about 0.4 grams, despite having quite a bit more mass. I’m hoping they have some serious penetrating power. I’ll give you guys an update after I try them out.
    76101DFF-C601-4EA3-9FCD-D6DB69372441.jpeg 1EA09C7F-7CF3-46E5-8212-2019BFE74E4F.jpeg CE923BF9-A156-4BAA-928D-4D668E255F0F.jpeg
  2. The Wood Wolverine
    I've been through a whole array of .22 pellets to try and find the most consistent. Those look awesome! Eager to see how they do.
    KSPlainsman, Horkn, Chvymn99 and 2 others like this.
  3. Eric Wanderweg
    Thanks. I'm a little nervous about the aluminum galling up the barrel, but I figured it's worth a shot (or 33). The aluminum is 7075 grade which is on the hard side, as far as aluminum alloys go. I have some copper I can try out on the next batch too.
  4. Eggshooterist
    Eggshooterist
    Erff
    Very cool. Definitely interested in how this works out. There is a lead bullet called Rat Sniper if I recall that is for 25 caliber pellet rifles. I'm starting to move into air rifles. Not as a replacement for powder burners, for something different and cheaper to feed. Even reloading isn't cheap anymore.
  5. Eric Wanderweg
    Update: I’m going to have to change the geometry on the O.D. of the pellet. Although I was able to accurately hold the size to match the Daisy pellets, because of the length of engagement when it hits the rifling, and harder pellet material, it jams halfway through the barrel. What I’m going to do is leave a narrow band of engagement in the front and rear of the pellet to catch the rifling. What I did from the start was turn a tapered pellet that was 0.176 at the front and 0.177 at the rear, and add 4 grooves along the O.D. thinking it would be enough clearance. Obviously I need a little more. Not a huge deal since I still have the machine set up :) Redo my geometry, load a new program and try again tomorrow.
  6. brenndatomu
    Slow day at the shop? :rofl: :lol:
    Pretty cool...
    Chaz, Sandhillbilly, Horkn and 4 others like this.
  7. Eric Wanderweg
    I’ve got a long cycle time with the current job on my machine, and the operator of the lathe across the aisle is out on vacation, as is my supervisor :whistle: :cool:
    41FanForLife, imwiley1, Chaz and 8 others like this.
  8. Eric VW
    My thoughts as well.
    Qualifying reasons… qualified.
    :handshake:
    Chaz, Sandhillbilly, Horkn and 5 others like this.
  9. moresnow
    moresnow
    We used to call that........ Government work. Lotsa stuff got done after hrs/dark etc:whistle:
  10. Eric Wanderweg
    Out here it’s still called government work, or G-Job for short. I can tell you that nobody works harder than the guy sneaking something in on lunch, or the one who comes in a couple hours early to knock something out before everyone gets there ;)
    Sirchopsalot, Softwood, Chaz and 8 others like this.
  11. Warner
    An old timer told me “you gotta find ways to make it worth your while”
    Sirchopsalot, Softwood, Chaz and 6 others like this.
  12. Eckie
    Eckie
    Hey, helps ensure equipment etc stays in good working order....
    Chaz, brenndatomu and Eric Wanderweg like this.
  13. brenndatomu
    Or helps wear it out...:whistle: :rofl: :lol:
    Chaz and Eckie like this.
  14. buzz-saw
    buzz-saw
    Ct.
    I tell them that all the time.
    Nice job Eric. They look great. I’ll be interested on the final report.
  15. KSPlainsman
    KSPlainsman
    Kansas
    What pellet rifle are you shooting these out of?
  16. ironpony
    ironpony
    Mid Ohio
    OK so, if you notice the shape of the rear of the pellet. The way it works is a slight press fit as it goes into the barrel. The lead is soft and self sealing/lubricating so it forms to and slides easily thru the barrel
    IMO I would go to a 6061 T0 aluminum which would be a much softer material. I would also add the recess in the back for flexibility,
    The pointed end would need to be a smaller, .020 microns in diameter and the rear end would need to be flared to acquire a seal and not create too much drag.
    A lot more machine work and multiple steps.
  17. Eric Wanderweg
    It’s just a cheap Crosman single shot break barrel, nothing fancy.
  18. Eric Wanderweg
    I was thinking 6061 would be better myself. All I had on hand in 1/4” round stock was 7075, so that’s what I ran with. The nose of the pellet has a 0.015” radius on it as it is, so it’s reasonably sharp. I agree there’s too much drag. Doing a secondary turning/drilling/boring operation on the back side will be tricky after I relieve the middle of the OD. Not much to hold by. The best approach might be flaring out the backside with a punch until I get the right diameter, which will take quite a bit of experimentation on my part. I’ll see what I can do though, thanks.
    KSPlainsman and brenndatomu like this.
  19. Eric Wanderweg
    New design done, waiting for an open machine to run off half a dozen in :whistle:
    Ron T, ironpony, MikeInMa and 3 others like this.
  20. brenndatomu
    Ron T and Eric Wanderweg like this.
