stove pipe leak
Discussion in 'Modern EPA Stoves and Fireplaces' started by Sirchopsalot, Dec 10, 2022.
  1. Sirchopsalot
    Sirchopsalot
    medium city in CT
    With the lights off last night, I saw light coming from the joining of the stove pipe and the wood stove.
    I'd like to seal that so it doesn't suck air from the room, but rather through the stove. I am thinking that a piece of door seal, tied tightly at the seam and pushed down on it, might work.
    I don't really want to use a glue or cement, as I'll be pulling this apart for cleaning seasonally.
    Is there anything else that would work better than door gasket material?
    SCA
    MikeInMa and Backwoods Savage like this.
  2. brenndatomu
    I'd just dab a lil furnace cement in the gap...it will crack off easily enough when its time to remove the pipe.
    Ron T, In the Pines, MikeInMa and 5 others like this.
  3. Backwoods Savage
    Probably still the best way.
  4. Locust Post
    Myself I like the gasket idea over the furnace cement. If I was going to use sealer I would try high temp silicone, it will take much higher temps than it is rated at.
    Sirchopsalot likes this.
  5. Hoytman
    Hoytman
    OH
    brenndatomu likes this.
  6. Dok440
    Dok440
    NorCal
    I'm a little concerned about seeing light through that area. Could you have burned through the inner wall?
  7. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Good thought. Its single wall right into the stove. If I look down into the seat where the pipe fits,.there is sometimes visible light.
    I kinda wish the fluted end of the pipe fit further into the hole, it seats.shallower than I would like.
    Sca
  8. moresnow
    moresnow
    One wrap of loading door flat gasket wrapped to cover/fill the gap. Wrap it with a large stainless clamp. Looks choice as well:rofl: :lol:
    It does work well, however.
  9. Warner
    Could you pop rivet the two pieces together?
