Tomorrow's Scrounge Subject to Change Without Notice
Discussion in 'The Wood Pile' started by buZZsaw BRAD, Dec 10, 2022.
  1. buZZsaw BRAD
    An unintentional follow up to last months "Today's scrounge subject to change without notice" thread. Work took me back to the same neighborhood yesterday and the same Asplundh crew cutting there. Planned on cutting today, but not here. Wasnt losing out so cut here instead. Some pretty decent wood. Small red and Norway maple and the rest sugar maple. IMG_2273.JPG IMG_2274.JPG IMG_2275.JPG Just a big shagbark hickory trunk left. May go back tomorrow or ASAP. IMG_2277.JPG Bigger load than i wanted. Brad from York & Buttermilk are a Brad influence! :doh:
    Cut all the maple and had to squeeze it on there. Left rounds behind last time and gone when i came back. IMG_2276.JPG IMG_2278.JPG IMG_2279.JPG Processed right off the PU till the splitter ran out of gas. IMG_2280.JPG Splits and whats left. IMG_2281.JPG IMG_2282.JPG IMG_2283.JPG
  2. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Looks good Brad and I don't think your truck is anymore loaded than your normal. Hope you can get the hickory tomorrow.
  3. buZZsaw BRAD
    It was loaded to the hilt. I even halved 12-14" diameter rounds to sardine pack them in. I had three saws in the cab even though the 462 didnt see action. Sugar maple is some HEAVY stuff too. Took it real slow on the 15 minute ride to storage.
  4. MikeInMa
    Nice getting.
    Good luck getting more.
  5. jrider
    jrider
    Thats a load on that truck!
  6. stuckinthemuck
    stuckinthemuck
    When I’m loading, I try to put as much wood as possible forward toward the cab and then less near the tailgate. I find that this reduces rear sag and moves the center of gravity closer to the front of the truck..
    that’s some beautiful wood!!
  7. GMB77
    GMB77
    South West NH
    Brad's springs are so worn out, that poor F150 is got it's rubber baby buggy bumpers on the axle all the time. He's modified the brake system with a second pedal so he can use the rear brakes to steer like a farm tractor.
    The amount of wood you scrounge, you should have one of these Brad
  8. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Hope you get that hickory!!!
  9. Backwoods Savage
    Looks good even if there was some rot there.
  10. Skier76
    Skier76
    CT and SoVT
    Even come with some pre-made candle rounds! I had some birch like that. Used a spade bit on a cordless drill and made some holes in the bottom. Burned great in the firepit.
  11. T.Jeff Veal
    That is a big and heavy load. Glad you got it. Make a new home for that shagbark too.
  12. Brad from York
    Brad from York
    York PA
    I would have had a hard time leaving the hickory behind. It’s 2 fold for me, good for the stove, better for the smoker!
  13. buZZsaw BRAD
    Can you imagine? See me towing that rig, stopping roadside picking up logs? Ive seen smaller versions of that where the operator stands on the back while using the controls.
  14. brenndatomu
    "Trail turn assist" is what Ford calls it on the new Bronco...allows you to apply the inside brake when the steering wheel is full lock...not available on any trucks though, that I know of.
    What is Trail Turn Assist?
    I notice that tailgate is pretty caved in there Brad...and looks like it would allow an extra inch or two of load capacity/room with the tailgate closed...;) :thumbs:
  15. buZZsaw BRAD
    Going back soon to get it. I didnt wanna overload! ;)
  16. grandgourmand
    grandgourmand
    Ontario
    Yeah post pictures of the hickory if you get it!
  17. buZZsaw BRAD
    I didnt plan it that way but its helps. My tailgates take a beating from wooding...obviously!
  18. buZZsaw BRAD
    You bet i will. Not sure with the slop this afternoon.
  19. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Just remember Brad, if you ever get a liftgate they add about an extra foot to the bed.:thumbs:
  20. stuckinthemuck
    stuckinthemuck
    With the way the highway patrol relentlessly harasses commercial operators in your state, you wouldn't last a full day with that thing behind your truck..
