The one tool I didn’t have
Discussion in 'Chainsaws and Power Equipment' started by Chud, Nov 20, 2022.
  1. Chud
    Chud
    :emb: Put a new detent valve on my splitter and this is what turned it into time consuming headache.
    I didn’t have a hex big enough to fit. Went through every tool drawer, box and bag twice and couldn’t find a bolt that might fit.
    Did some g searches looking for tools needed to install prince valve and couldn’t find anything. $&@“!
    Trip to autozone and they didn’t have any individuals big enough. The guy there recommended hf, but that’s 30min away and this quick fix had already exceeded my level of patience, so I bought the set. :makeitrain"
    I try to leave and my truck door won’t open. Ooph
    The good news is that there are no leaks.
    metalcuttr, Chaz, KSPlainsman and 9 others like this.
  2. Screwloose
    In a pinch a bolt of the proper hex size and vice grips or a pipe wrench on the bolt shank works.
    Edit i missed the bolt part.
    metalcuttr, Chaz, Camber and 5 others like this.
  3. brenndatomu
    I've even got lucky before and found a punch the right size!
  4. Chud
    Chud
    Oh chit, I didn’t think about punches. I have a set with one that might have worked.
    metalcuttr, Chaz, Camber and 3 others like this.
  5. JimBear
    JimBear
    Punch or chisel shaft or in a pinch find a chisel that fits diagonally & use a pair of vise grips or a wrench on the shaft end.
    metalcuttr, Chaz, KSPlainsman and 6 others like this.
  6. Camber
    Camber
    Montana
    This is what I have done. Used a cheap cold chisel and tuned it with a grinder. worked slick.
  7. buzz-saw
    buzz-saw
    Ct.
    A bolt works if it isn't too tight ; I have done that in the past.
    Or the good old belt grinder and a piece of round stock and grind your own.
    Look at the bright side ; you now have a set. So chances are you will never need them again.
  8. Chud
    Chud
    Yup, that’s why I have a tool collection with multiples of the ones I never need.
    Haftacut, Camber, metalcuttr and 3 others like this.
  9. GrJfer
    GrJfer
    The Woods of Arkansas
    A design engineer somewhere is having a good chuckle over this.
    Chud likes this.
  10. Chud
    Chud
    A plastic dust cover with a pull tab would be more user friendly for folks that don’t own a 9/16 hex.
    Screwloose and GrJfer like this.
  11. Screwloose
    That would totally inhibit the ability of some yahoo at the factory to run them home with a 1" impact making them stuck as heck!
    brenndatomu and Chud like this.
  12. Chud
    Chud
    Before it’s glued with paint
    Screwloose and brenndatomu like this.
