“It’s dead Jim”
Discussion in 'The Wood Pile' started by Timberdog, Nov 15, 2022.
  1. Timberdog
    Timberdog
    Az
    I was cutting this nice dead standing ponderosa pine and by the time I got to bucking my fourth round my saw died. I’ve never had one do this to me before. It kept bogging down slower and slower until it just gradually died. Then the body just started smoking because it was so hot. I was afraid to try and restart it for fear it might catch fire. So I set in in my truck and finished up with by little electric back up saw. I checked the fuel tank and it was still half full. When I came back it was sitting in a big puddle of oil. Any ideas what the issue is? It’s a Stihl ms 291.
    61A51623-D505-4B53-A599-1512FF3EFE3F.jpeg 2D5C6B47-2D2E-4A4C-A1D4-F3833824E8D2.jpeg EE6A9DD3-665B-4C82-BA9E-339895565810.jpeg 4C65CF3A-70C9-4EEE-9EE0-0EDB91A86CF9.jpeg 88BAC255-27C0-4938-BB23-3B890F8F68EF.jpeg 345E3DF5-8DF6-484F-B7A8-7809E6FC5AC4.jpeg F2F3A40D-0F44-4795-9C9D-C49D7B5E0246.jpeg
  2. jo191145
    I’m not a mechanic. WAG you either toasted some crank bearings or burnt a hole in the piston. Something forced the cases apart to allow the oil reservoir to also leak.
    Guess it’s also possible the case gasket let loose in the crank area and outside at the same time.
    Is the plug full of oil?
  3. Theashhole
    Theashhole
    Osceola, In
    Did you change the carb at all? That's a chitty day (even if it's a Stihl:D)
  4. saskwoodburner
    saskwoodburner
    "If your saw can't handle you at your worst, it doesn't deserve you at your best"
    -someone, probably
    Aje1967, Horkn, Cash Larue and 14 others like this.
  5. imwiley1
    imwiley1
    Wisconsin
    Check the clutch and drum sprocket.
  6. The Wood Wolverine
    Remove the muffler and inspect the piston through the exhaust port. I'm guessing it's scored pretty hard. A new top end (or at the least a piston) is in its future if so. Just need to figure out why it did that in the first place before moving forward.
    Look like this?
  7. Timberdog
    Timberdog
    Az
    I replaced the drum sprocket recently. What else should I look for?
    Horkn, Cash Larue and Chazsbetterhalf like this.
  8. Timberdog
    Timberdog
    Az
    I will have to tear into it. Maybe when I have time in a few more days. Thanks for the input. I will post what I find then.
  9. imwiley1
    imwiley1
    Wisconsin
    Having replaced it recently likely eliminates it as a cause. I have seen saws that were neglected and the drum worn so thin it breaks apart. Some continued to run it and melt the case surrounding the clutch area until the saw just bogs and quits. The Wood Wolverine has great advice.
  10. Mag Craft
    Yep, you need to pull the muffler off and then look into the exhaust port. Pull the spark plug and then try and pull it over real slow while looking at the piston moving up and down.
  11. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Too much white on the outter shell. . . .
  12. The Wood Wolverine
    Glad I wasn't the first to say it. :D:rofl: :lol:
  13. jo191145
    :rofl: :lol::rofl: :lol:
  14. Sirchopsalot
    Sirchopsalot
    medium city in CT
    No, its not the brand. I really have no preference or loyalty, almost owned a Stihl a few weeks ago, and wouldnt have felt like I was betraying anyone if I had.
    Any mechanical device is prone to breakdown.
    Hope you figure out the issue Timberdog , looks like the start of a good score.
    How do you loke dispensing gas from that gas can? I just got one like it, but haven't used it on a saw yet....
  15. Timberdog
    Timberdog
    Az
    Yeah, it’s scored. Guess it’s going to need a new cylinder and piston…
  16. Timberdog
    Timberdog
    Az
    Easiest gas can to use ever!
  17. Warner
    Jill’s jugs are the best.
  18. Timberdog
    Timberdog
    Az
    Indeed!
  19. The Wood Wolverine
    Sometimes the cylinder can be saved. The issue is finding what caused it to probably leak air to cause the scoring. No chance it was straight gassed?
  20. The Wood Wolverine
