Hand Sharpening Options
Discussion in 'Chainsaws and Power Equipment' started by The Axeman Commeth, Nov 15, 2022.
  1. The Axeman Commeth
    The Axeman Commeth
    Fridley MN
    I hand sharpen my chains with the Husqvarna file kit. It does a good job for me but I have worn it out and needs replacement. Though I am totally satisfied with the Husqvarna kit I am curious to others opinion of it or if anyone feels another option is better and why. Thanks.
    Screwloose likes this.
  2. In the Pines
    In the Pines
    I think a lot of ppl here are using the electric sharpeners. I still use a granberg contraption myself.
  3. Chud
    Chud
    What does the kit consist of?
    I use the Husqvarna file roller on .325 chain and the depth gauge plates for .325, 3/8 and .404. Unless arthritis wrecks my hands, I’ll always hand file.
    Screwloose and walt like this.
  4. The Axeman Commeth
    The Axeman Commeth
    Fridley MN
    I use the same one. It's the only one I have ever used so I am just curious as to other's experiences.
  5. The Wood Wolverine
    I think they (the roller guides) work great and eventually help you learn to file without the guide. The method of maintaining the depth gauges/rakers with the plate on the guide is by far the best IMHO. If you wanted to get another tool/toy, look into the Timberline. You're not going to get sharp quicker but those jigs do a great job of making every single cutter exactly the same length/angle etc. And the finish it leaves on the cutter is very fine.
    I moved on from round filing to square a couple years ago and never looked back. The files for this method are not cheap and the learning curve is steep. BUT, it cuts faster than round, is smoother and holds it edge better. I eventually sold a ported saw to fund a grinder that can sharpen square. You will never catch me cutting without a razur sharp chain.
    Timberline Chainsaw Sharpener | Sharpen your chainsaw the faster, easier way with Timberline Chainsaw's patented sharpener.
    Screwloose and Ralphie Boy like this.
  6. ReelFaster
    ReelFaster
    S.Jersey
    I love my Stihl 2 in 1, IMO it is the best all around. It's fast, its easy, does the rakers, and it sharpens extremely well. Only con is it's a bit pricey but worth it to me.
  7. The Axeman Commeth
    The Axeman Commeth
    Fridley MN
    Can you use multiple file sizes and is it easy to keep the correct angle while filing?
    Screwloose, theburtman and ReelFaster like this.
  8. ReelFaster
    ReelFaster
    S.Jersey
    Yes and Yes. That orange area pops open to swap out files. The way you align it on the chain allows for almost perfect angle every time. You can't really hold it any other way but the correct angle. I just learned/noticed the other day after having for a few years there are marks on the file showing the correct angle along with the edge of the tool showing the correct angle. If you have time check out some reviews on youtube it's really a great tool.
    Screwloose and theburtman like this.
  9. ReelFaster
    ReelFaster
    S.Jersey
    This guys crack me up, sponsors each video with a different beer.
  10. The Axeman Commeth
    The Axeman Commeth
    Fridley MN
    Can you use for different pitch chains or is it pitch specific?
    Screwloose and ReelFaster like this.
  11. Yawner
    Yawner
    Louisiana
    I have gone to using a Dremel. So far, game changer for me. Easy, effective, no hand pain. Will keep using until convinced otherwise.
  12. ReelFaster
    ReelFaster
    S.Jersey
    Pitch specific
  13. ReelFaster
    ReelFaster
    S.Jersey
    Unless you need to sharpen out in the woods.
  14. Yawner
    Yawner
    Louisiana
    It’s an advantage, actually, as mine is cordless. And I’ve been sharpening by eye, no attachment.
  15. ReelFaster
    ReelFaster
    S.Jersey
    Sweet!
  16. buZZsaw BRAD
    I freehand with just a file or use in a filing guide.
  17. isaaccarlson
    isaaccarlson
    Colfax, WI
    I carry a file in my little tool kit just in case. I carry several chains and swap them out when needed, then grind at home. I like the consistency of ground chain.
  18. Meche_03
    Meche_03
    Missouri
    I have 3 different pitches of the 2-1 along with individual files. The 2-1 does a good job, especially for a quick touch up when refueling. The 2-1 doesn't take the depth gauges down as much as I like so I use a flat file and a progressive plate when I feel the saw not pulling as hard as I want. I will use a round file after the 2-1 sometimes too. I can feel the round file grabbing for a pass or two even after the 2-1 sharpened a chain. Maybe I need new files for the 2-1 but I can see it pulling metal still.
    theburtman likes this.
  19. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    I have a Timberline sharpener I'll sell with extra cutters and parts. I purchased a Superjolly and a CBN wheel and never went back to the Timberline.
  20. The Wood Wolverine
    I honestly don’t use mine much either. Got a square grinder so the only use it gets is when my brother-in-law asks me to sharpen his chains.
    The Axeman Commeth I’d hit up Ralphie Boy on his if you want a new toy/tool. :thumbs:
