MS200T Twins
Discussion in 'Chainsaws and Power Equipment' started by LordOfTheFlies, Nov 15, 2022.
  1. LordOfTheFlies
    LordOfTheFlies
    NY
    First one that has good compression had a filthy air filter. Also the fuel filter cap fell off, weight was off, and the foam insert clogged with sawdust. Going to clean it up and see if she runs.
    I sprayed the air filter with brake cleaner and it did a great job of cleaning it up.
    IMG_20221114_114536_909.jpg IMG_20221114_132857_020.jpg IMG_20221114_132855_390.jpg IMG_20221114_134129_121.jpg IMG_20221114_132710_191.jpg IMG_20221114_130153_410.jpg IMG_20221114_130115_925.jpg IMG_20221114_125951_630.jpg
    jo191145, M2theB, SimonHS and 8 others like this.
  2. Eggshooterist
    Eggshooterist
    Erff
    Hoe lee ....
    Air compressors must not exit in the place those saws came from.
  3. buzz-saw
    buzz-saw
    Ct.
    ^^^ x2 ^^^
    Air compressor and a minute of your time when done cutting makes all the difference in the world.
  4. Chud
    Chud
    Not saying those saws ever got cleaned, but 200,201’s wad up the filters worse than any saw I’ve used. One use and they are packed. I looked at buying a 200t a few weeks ago. Couldn’t find one out of 4 that didn’t have issues.
  5. Warner
    “I can’t breathe! ”
    jo191145, Stephiedoll, M2theB and 8 others like this.
  6. buZZsaw BRAD
    WOW! Is either of them for sale?
  7. LordOfTheFlies
    LordOfTheFlies
    NY
    Not at this time. In fact, there's another set of ms200t twins that needs to be looked at. I'll ask but I don't think so either.
    Very excited to do a piston/cylinder on a top handle saw as I have not done one previously.
  8. LordOfTheFlies
    LordOfTheFlies
    NY
    Well there was a 201tc I fixed yesterday that wouldn't shut off with the switch. It too was just as filthy as these. I just stripped it down, cleaned the big parts in the parts washer, put it back together, and it worked. So there you go right there - evidence suggesting that keeping your saw clean will help keep it running properly. When I say filthy I mean filthy.
    jo191145, eatonpcat, JD Guy and 3 others like this.
  9. LordOfTheFlies
    LordOfTheFlies
    NY
    Took a look at the second one and yeah it needs a piston and cylinder. The soark plug hole is stripped. The old plug came out weird and would go back in...weird....and when I tried to put a new plug in, no dice. The plug wasn't even in the hole which is why it had no compression. The tip of the plug was also broken and stuck inside the plug wire.
    M2theB, eatonpcat, Chud and 2 others like this.
  10. buZZsaw BRAD
    Thanks. Not that i need one but hearing so much about them its on my bucket list.
    Looks like those were just used and used and abused.
    Are you doing small engine work part time LOTF?
  11. Scotty Overkill
    Those are the most desired saws of most climbers, I've got 6 of them (200T's and 020T's), they are definitely one of the most powerful top handles ever built and worth repairing. Mine don't see much use in the tree nowadays though, thanks to these modded Echo CS2511T's....
    jo191145, Stephiedoll, M2theB and 5 others like this.
  12. buzz-saw
    buzz-saw
    Ct.
    Can you get away with a heli-coil thread insert?
    Might be an easy way out if the piston and cylinder look good
  13. LordOfTheFlies
    LordOfTheFlies
    NY
    I'm just helping out a buddy who needs help. But it does feel good to bring stuff back to life that was destined for the garbage. Plus I really enjoying the learning of a new skill part.
  14. LordOfTheFlies
    LordOfTheFlies
    NY
    So another weird thing these plugs are supposed to be 14mm and the new one is.....but the old one measure over 15mm. I think this saw got super over heated and the plug popped out of it. The hole for the plug is too big for the new spark plug!! It will not catch any threads at all and both are NGK BPMR7A plugs! So I whipped out the caliper and lo and behold this is what I saw (no pun intended):
    BuckthornBonnie MasterMech M2theB have you guys seen this before???
  15. buzz-saw
    buzz-saw
    Ct.
    Well that is interesting. Never seen a plug with that thread but when I get a minute I am going to do a little homework.
    I have seen 14mm , 18,mm some massive thread they used in tractors from the 40's but never that.
    Do you think at one time the original 14mm got stripped so someone found that plug with a larger thread and rethreaded it to make it work?
  16. buZZsaw BRAD
    I admire your enthusiasm for the learning part. :salute: For some reason working on small or even large engines doesnt appeal to me in the least. If i havent already, ill compliment the work you do and how thorough you are in doing it. :thumbs:
    Eggshooterist and LordOfTheFlies like this.
  17. LordOfTheFlies
    LordOfTheFlies
    NY
    Thanks man appreciate it. I think I've said it before it's very similar to working on computers or cars. My old life was being an IT guy and I do almost all of the wrenching on my vehicles so this type of work becomes me.
    buZZsaw BRAD and Eggshooterist like this.
  18. LordOfTheFlies
    LordOfTheFlies
    NY
    I saw this at the dealer the other day. $799 for a MS201TC. That was the price of a 372xp not too long ago! Now those are $1150 with a 24" bar!!!
  19. Rickyblazin
    Rickyblazin
    Pottstown PA
    Thats why i snagged my redmax(husquvarna) top handle brand new on ebay soon as i seen the price drop to 320 free shipping…these new orange saws are unaffordable for me
  20. Wolley
    Wolley
    Looks like an insert or helicoil stuck to the old plug.
