Need some advice
Discussion in 'Chainsaws and Power Equipment' started by Creekin, Sep 1, 2022.
  1. Creekin
    Creekin
    Manitoba
    Hopefully going to look at a bobcat 1600 articulated wheel loader tonight or tomorrow, and I can't seem to find alot of info just doing a search
    Do any of you guys have any experience good/bad with them?
    Unfortunately don't have alot of info as far as hours or condition, being an estate sale my aunt knows little about it
    Knowing the kind of person my uncle was, it shouldn't be a complete basket case
    I'll check in with more details soon
    Thanks, Mark
  2. Haftacut
    Haftacut
    Rives Junction, MI
    Helps to know who owned it. Let us know what you think after checking it out.
    amateur cutter and Screwloose like this.
  3. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Take pictures.:ithappened:
  4. Creekin
    Creekin
    Manitoba
    Had a look at the unit the other day, cosmetically needs some help
    Had a so-so repaint
    Engine started with boosting ( kubota), runs well otherwise with minimal smoke and revs up nice
    Hydraulics work for the mast and bucket
    Forward and reverse are painfully slow,but think there is some issues with the linkage from the pedal to the hydrostat being tight/stiff
    Has aux Hydraulics which is a plus
    No cab heater, but thats easily dealt with
    Cab windows and doors need some help definitely!
    Tires in good shape
    Hour meter shows about 1500 hours, who knows if it works (didn't run long enough to check)
    Mainly will use the unit for snow clearing and obviously firewood duty
    Makes me a bit nervous that theres little info online about them
    I'll post some pics as soon as I can get better cell service
  5. clemsonfor
    Have you got better service yet? Did you buy it?
    I have zero experience with skid steers so other than general equipment and knowledge of stuff I can offer little help.
    amateur cutter likes this.
  6. Creekin
    Creekin
    Manitoba
    I haven't bought anything yet, just got a price the other day which i thought was somewhat reasonable to offer what i think its worth
    Just trying to get some funds together
  7. Creekin
    Creekin
    Manitoba
    Well i figured i should update this thread
    I ended up buying the loader and brought it home
    The biggest problem I was having is i couldn't find a serial number on the unit, knew it wasn't stolen or a bank lean on it
    The biggest reason was being able to lease it for the business, which i ended up paying for it cash instead
  8. Creekin
    Creekin
    Manitoba
    After some much needed maintenance ie changed engine oil, greased everything, (which i don't think had seen grease in years)
    Was able to clear the first snowfall of the year
    Not pretty, but sure works well!
  9. Creekin
    Creekin
    Manitoba
    Ended up repairing the loader upright(?) That had rotted through with a fresh 1/4" steel plate (grey area)
    Need to fix a hydraulic leak by the resevoir tank, which I'm hoping will be an easy fix
    It spent the first few years of its life in a fertilizer plant not far from here
  10. amateur cutter
    Had one 20 plus years ago. Good machine. Wish I had kept it. Nice find.
