John Deere 4052R
Discussion in 'Chainsaws and Power Equipment' started by SKEETER McCLUSKEY, Mar 22, 2018.
  1. fuelrod
    fuelrod
    Western Maine
    What grill are you going to cook him on?
  2. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  3. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  4. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  5. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    the little echo is blowin 200psi now
    thewoodlands likes this.
  6. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    thewoodlands and eatonpcat like this.
  7. Warner
    eatonpcat and fuelrod like this.
  8. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    no....:rofl: :lol:
    eatonpcat likes this.
  9. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Predator 3500 carb...i been in it a couple times and had it running good. ..it had a serious lope to it when i took it outta the box.i put a oem honda #70 main in it and oem honda pilot jet cause the orings on the predator ones are junk 20220908_123607.jpg
  10. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    eatonpcat, thewoodlands and fuelrod like this.
  11. Warner
    Cute wheels! image.jpg those things are a bitch to move around without them. Never mind get on a tailgate
  12. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Ill be ok,cause it dont move...i mean it does a little...i drag it out the door and the vibes from it cause the 4 little wheels to make mud patties and sink in til the belly is resting on the ground:rofl: :lol: but it wont roll away!!
  13. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    But i am gonna put wheels on my bigger honda powered gen...its just on skids and too heavy to handle without a tractor
    thewoodlands and Warner like this.
  14. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    RichE23ACR, eatonpcat and fuelrod like this.
  15. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    20220917_093008.jpg Nother one for porting...
    eatonpcat and Chud like this.
  16. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    28 ton tractor supply splitter ...ram won't move.....hmm plastic thingy blocking suction line 20221106_175152.jpg
  17. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  18. fuelrod
    fuelrod
    Western Maine
    "Plastic thingies", the ruination of all things good and simple. :whistle:
    SKEETER McCLUSKEY likes this.
  19. buzz-saw
    buzz-saw
    Ct.
    I like that wing-nut you made.
    Guess what I will be making at work this week. Thanks for the idea!
  20. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    I made it out of a lug nut,and I turned down a washer so it was a press fit to the hole in the timing wheel.....the large handle makes it easy to make small adjustments 20221107_091417.jpg
