New wood shed build
Discussion in 'The Wood Pile' started by Sandhillbilly, Oct 31, 2022.
  1. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Really seems more like a rack but it’s gonna have a roof. So that makes it a shed, right?
    Right at 40 ft long. Plastic pallets on 8” steel pipes. Chain link fence on the backside to help prevent stacks from falling, and deter any easy theft from the street. It will have wooden pallets for ends and dividers. Probably gonna be 6’ in the back and 7’ in the front with a steel roof.
    This is as far as I got over the weekend
    693F02E2-EB7E-4B34-99AB-795B649A9332.jpeg 8B21028E-51AD-40BE-8073-F73E9D901655.jpeg C66F9513-9FDB-42CE-808D-091368FF2DC4.jpeg 3C71562C-9398-4D13-B999-D3AA694E7501.jpeg
    you people have really changed my approach to storing firewood
  2. buZZsaw BRAD
    Made some good progress. :thumbs: Gonna be able to get a few cords in there. :stacker:
    Glad that were able to be a positive influence.
    amateur cutter, Chaz, Horkn and 13 others like this.
  3. The Wood Wolverine
    That'll make a nice privacy fence too! :dex:
    amateur cutter, Chaz, Horkn and 12 others like this.
  4. Sandhillbilly
    Sandhillbilly
    That’s kinda part of the overall plan. I have room to go probably at least another 40’. Might have to leave a gap to get the mower and water hoses through. I’ll also need more plastic pallets to go that far. But this is probably big enough to hold everything I have that’s needing processing
  5. Stinny
  6. Sandhillbilly
    Sandhillbilly
    I was about 18” short on the chain link fence Last weekend. So I got the chain link finished up and 3 pallets up on Friday evening. Got the rest of the pallets up this afternoon.
    hoping to get the tops tied together tomorrow, we’ll see if that happens.
  7. KSPlainsman
    KSPlainsman
    Kansas
    So are the dividers going to be for keeping seasoned and non seasoned wood separate, or for different species, or both perhaps?
    It looks great so far! That should hold about 6 cord, if my math is right. Not bad at all. Good job!
  8. Sandhillbilly
    Sandhillbilly
    Yep, kinda keep it sorted a bit. Species, whether it was taken dead or alive, etc…. I’m thinking one of the small sections might end up with a barrel of the small limbs that I use to tie the rows together for stability, maybe a lick tub full of splitter shards for kindling, hang my peavy in it and that sort of thing.
  9. Sirchopsalot
    Sirchopsalot
    medium city in CT
    impressive. modular too, just finding pipe or poles to add in any direction...
    I'm looking forward to pics of finished stacks!
    SCA
  10. KSPlainsman
    KSPlainsman
    Kansas
    Sounds great! I look forward to seeing it finished. I use longer thin limbs to hold together my stacks as well.
    amateur cutter, Chaz, Horkn and 6 others like this.
  11. Sandhillbilly
    Sandhillbilly
    I Got access to plenty of pipe, telephone poles also right now. Wood pallets are plentiful around here. Gots plenty of chain link fence available. But plastic pallets for the base are another matter….. I have 2-3 not being used right now and should have 4-5 more freed up come spring
  12. mr.finn
    mr.finn
    Mass
    That looks like a great setup. Plenty of sun and wind to dry the wood out.
  13. brenndatomu
    What length do you cut to? You will be able to stack 2 rows wide on those pallets...maybe they are wider than they look in the pictures? Pretty cool having access to all that pipe!
  14. Sandhillbilly
    Sandhillbilly
    I try for 18” ( even measuring and marking I don’t always make it) so, yes, 2 rows with a space in between for nuggets and such. Plastic pallets are 42 inches by 48.
  15. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Looking good, be nice to see the finished product. Thinking I may evolve to using totes to stack my wood in. Better chance they won't fall over that way.
  16. T.Jeff Veal
    That's looking great. Very nice job.
  17. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Sandhillbilly any stacking yet?
    And, have you figured out the cord volume if you're stacking to 6'?
    That will be an impressive wall once you're done!!
    SCA
  18. Canadian border VT
    Yeah this started on Halloween it’s thanksgiving ;)
  19. Sandhillbilly
    Sandhillbilly
    Just barely, got sum finely split mulberry for smoking wood in it. But I’m thinking about pulling it back out and putting in a shelf for it and put my apricot smoker wood in there to
    got the top of the uprights tied together last weekend, shoulda done that before I stretched the chain link across the back and pulled the posts out of plumb. But oh well it’s just a wood shed.
    I’ve gotten a few comments about it already, one guy asked, “ do you think it is big enough?”.
    My reply = “not even close”
    Saturday should bring noticeable progress
    amateur cutter, Chaz, JimBear and 6 others like this.
  20. Sandhillbilly
    Sandhillbilly
    Patience grasshopper…. I’m not buZZsaw BRAD
