I have a question for you gu-roo's out there in wood hoarding land!
Discussion in 'Chainsaws and Power Equipment' started by Dougr6, Aug 28, 2014.
  1. Dougr6
    Dougr6
    Caney Ks.
    I noticed on my Stihl 391, with 20'' bar, the bar number 3003 000 9421 is O.E.M. for the 460R . Rescue saw. ( pitch: .375/ gauge .063)
    With a web search I see that it runs a #36 RDR 72 o.e.m. chain. I wanted to order a couple for this winter from Bailey's in the Woodland Pro brand. Do you have any recommendations? I will be felling white oak and hedge mostly, 14'' dia. trees on the average.
    4 cords at most. Thanks for your advice.
  2. SquareFile
    SquareFile
    somewhere
    I'm confused by your post:cheers: my fault. Both saws can use the same bar and chain. I would recommend a semi chisel chain. Your gauge will be etched in your bar. .050 or .058 or .063
    Hope this helps
    Dougr6 likes this.
  3. Dougr6
    Dougr6
    Caney Ks.
    Most my post are confusing. Sorry, I will try the semi chisel. Gauge says .063 and pitch is .375 or 3/8 Thanks again for the help.
    Chvymn99 and SquareFile like this.
  4. clemsonfor
    Thats a random gauge...where are you? All .375 around here is .050.
  5. clemsonfor
    I have run woodland pro. I liked it but baileys has horrendous shipping prices so I rarely order from there. Last chains I have bought were off ebay. I like stihl oregon woodland pro and some do greater chains have seemed ok as well
    Dougr6 likes this.
  6. Dougr6
    Dougr6
    Caney Ks.
    Clemsonfor, I am in southeast Ks. Got saw in Independence Ks. at Linn's air cooled engine shop. I see that its a oddball size. The bar came with the saw. At the time I didn't have a clue as to witch bar should of came with it. Is there a difference in the regular bar and rescue bar? Besides the 3/8'' instead of the standard 0.050? I guess what I need to know is, will a regular sawblade run okay on it?
    Chvymn99 likes this.
  7. MasterMech
    36RDR is going to run you a couple hundred bucks a loop. (Rescue Carbide chain). Sure you want spares? ;) :p
    You would have better luck using 36RS (chisel) or 36RM (semi-chisel). You most likely have 36RM3 (semi-chisel reduced kickback) on the saw now if it's the factory chain and using 36RS or it's Woodland Pro equivalent would be a nice upgrade in cutting speed I'm sure.
  8. Dougr6
    Dougr6
    Caney Ks.
    Thanks Master! You got me going in the right direction!
    Chvymn99 and MasterMech like this.
  9. DexterDay
    To add onto what MasterMech said, you can run any chain that is 72DL x 3/8" x .063
    What those numbers mean, is its 72 Drive links (for your 20" bar, you must always buy a 72 dl chain), the 3/8" (is the pitch of the chain, or also seen as .375), and finally the .063 is the bar gap width. You can only run .063.
    http://www.baileysonline.com/Chainsaw-Chain/Chainsaw-Chain-375-Pitch-x-063-Gauge/
    Dougr6, papadave, Drvn4wood and 3 others like this.
  10. HittinSteel
    HittinSteel
    Wooster, Ohio
    Mastermech and Dex have you all taken care of with their posts.
    Happy cutting with the new chains!
    Dougr6, basod, Chvymn99 and 1 other person like this.
  11. basod
    basod
    Mount Cheaha AL
    Funny I just bought a new loop of 36 RS 72 the other day - they didn't have them on the display rack, I had to show the salesman(kid really)where they keep them in the drawer:rofl: :lol:
    Dougr6, clemsonfor and concretegrazer like this.
