What's wrong with this clutch?
Discussion in 'Chainsaws and Power Equipment' started by LordOfTheFlies, Oct 14, 2022.
  1. LordOfTheFlies
    LordOfTheFlies
    NY
    Hint. Chain won't stop spinning at idle.
    Screwloose, M2theB and Haftacut like this.
  2. Creekin
    Creekin
    Manitoba
    One spring not seated in the hole?
  3. Creekin
    Creekin
    Manitoba
    Broken, pictures are a bit small on the phone
    Screwloose, LordOfTheFlies and M2theB like this.
  4. Haftacut
    Haftacut
    Rives Junction, MI
    Broke spring
  5. LordOfTheFlies
    LordOfTheFlies
    NY
    Yep. The chain was spinning at idle. Took a spare clutch from another broken MS194t that I had and works like a charm now. Ground wire had also rattled itself loose at the coil so I gave it a little pinch and put it back on. Switch now shuts the saw off. Yay.
    Haftacut and Screwloose like this.
  6. buzz-saw
    buzz-saw
    Ct.
    Yup broken spring isn't going to hold the end of that shoe , well actually shoes since they both rely on the same spring.
  7. Screwloose
    Clutches are for sissy's
    Stephiedoll and Chud like this.
