Cutting a telephone pole
Discussion in 'The Wood Pile' started by Yawner, Oct 10, 2022.
  1. Yawner
    Yawner
    Louisiana
    Any problems using a chainsaw to cut a pole? I assume that telephone poles here are pine. Used to be treated with creosote. My brother wants to cut one for a neighbor, use one of my saws. Any issues? I know they are hard; I guess that is from the treatment. They last many a year. Use a good saw or a crap saw?
    I don't know what the pole is for. Not a telephone line!
  2. sirbuildalot
    sirbuildalot
    Mass
    Should cut it fine, assuming its an unused pole that doesn't have 10,000 nails and staples in it.
  3. jo191145
    If it’s treated with creosote it’ll kill the chain pretty fast IME. Pressure treated is fine.
  4. Ohio
    Not Ohio
    I cut some telephone poles with my ms251 for a friend. I used my least valued saw and used a chain that if it were ruined I did not care. It worked out fine. The only reason they called me was the batteries for their snapper brand battery saw had gone dead.
  5. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    I’ve cut several and haven’t had any problems. Often times there is a copper ground wire running the length of them. So watch out for metal and you’ll be fine. Maybe use a chain that’s about due to be sharpened anyway.
    Not that big of deal
  6. buzz-saw
    buzz-saw
    Ct.
    Depends if you feel lucky ? " Well do you punk ?":smoke:
    Big question I would have is metal? Any poles around are more than likely full of staples if nothing else.
    x2 on throwing a so-so chain on it and send it"
  7. Smokinpiney
    Smokinpiney
    "South" Jersey
    I've cut plenty of them (creosote and treated). I always throw on a chain that I won't mind tossing in the trash if needed, just in case. The creosote will definitely put a hurtin on a chain after a few cuts.
  8. Eggshooterist
    Eggshooterist
    Erff
    My buddy is a lineman. They all have chainsaws with them for removing old damaged poles or whatever else they need.
  9. Mag Craft
    I have cut several poles in half, length wise for stacking some of my firewood on. I got through them both, but I did have to resharpen the chain several times.
    I used a circular saw one time on a pole and killed that blade in nothing flat.
  10. jo191145
    You know this guy?
    Sorry couldn’t help it. :)
    How bout we hit it hard again in the morning?
  11. Eggshooterist
    Eggshooterist
    Erff
    He told me the rest of the guys he works with have zero clue on operating, tuning, maintaining or sharpening a saw. And they all buy their own. Probably like the above situation lol. He has been teaching them as he was a logger for the national forest for a couple years way back. This lineman crew was throwing out new chains when dull. Some Not even rocked, just dull. No idea on sharpening.
  12. KSPlainsman
    KSPlainsman
    Kansas
    As others said, a chainsaw will be fine, but I always use a Milwaukee reciprocating saw, with a 12" blade on it. Gets through a bit slower, but at least I'm not intentionally wrecking a chain.
  13. Haftacut
    Haftacut
    Rives Junction, MI
    Pretty much sums it up for several lineman I know:rofl: :lol:
