Sharpening the Bottom of the Chain
Discussion in 'Chainsaws and Power Equipment' started by Rothk, Oct 6, 2022.
  1. Rothk
    Rothk
    WVA
    I saw this in the CS-590 manual:
    I've never done this - is it actually important? If so how often should it be done?
    metalcuttr, M2theB, Horkn and 7 others like this.
  2. theburtman
    theburtman
    This is the first I've heard of this.
  3. jmb6420
    jmb6420
    Grand lake, Oklahoma
    Never. Not once. Didn’t even know it was suggested!
    Mike in Ok
    metalcuttr, M2theB, Horkn and 4 others like this.
  4. farminkarman
    farminkarman
    Neenah, WI
    Same here
    metalcuttr, M2theB, Horkn and 3 others like this.
  5. James Miller
    James Miller
    Hanover PA
    Don't remember that in the 590 manual. I'll have to look through it.
  6. Chud
    Chud
    I don’t recall ever seeing that in the old fashioned Oregon sharpening manual.
    metalcuttr, Horkn and amateur cutter like this.
  7. MuddyPaw
    MuddyPaw
    North Central Ohio
    It might be an Echo thing. Pretty sure it's in both my 501p manual and the manual I downloaded for the 40+ y.o. 750evl.
  8. The Wood Wolverine
    Nope, never bothered and I'll bet you'll be hard pressed to find someone that does.
  9. buZZsaw BRAD
    First ive heard of it too.
    Maybe if you flip the chain inside out and cut???:rofl: :lol:
  10. buZZsaw BRAD
    mebbe its in the new one???:rofl: :lol:
  11. Haftacut
    Haftacut
    Rives Junction, MI
    “Drive link serves to remove sawdust” hmmm, I feel like it serves to drive the chain!:rofl: :lol: I also have never heard of this. File the occasional burr of a drive link, yes. Is this what they refer to as “sharpening”?
  12. Haftacut
    Haftacut
    Rives Junction, MI
    And even harder pressed to get any of us to buy into the concept:rofl: :lol:
  13. The Wood Wolverine
    Truth. I've seen this before, can't remember where but never blinked at the idea.
  14. Sawdust Man
    Sawdust Man
    Pretty sure that's pure bogus....
    I've spent thousands of hours running saws and never once have I "sharpened" the drive links....
    But what do I know, I ain't got no degrees in nonsense....
  15. buZZsaw BRAD
    Do you think it would "cut" better if it was square ground? :rofl: :lol:
    metalcuttr, M2theB, Horkn and 5 others like this.
  16. corncob
    corncob
    Somewhere in Lower Michigan
    I think it would destroy the drive sprocket pretty quick.
  17. isaaccarlson
    isaaccarlson
    Colfax, WI
    The drive tooth doesn't even touch the bottom of the bar groove.
  18. MikeInMa
    If there's actually "sawdust ", then your cutting teeth need to be sharpened. Unless, you're milling and sawdust is unavoidable. I can't think of why they'd need to be sharpened otherwise.
  19. The Wood Wolverine
    It does if you've dressed/filed your rails down far enough. I've personally not gone that far. That's why this tool has lines on it:
  20. huskihl
    huskihl
    I believe the idea is that it helps clean the bar rails out and then ejects the goo as the chain comes out of the bar and around the drive sprocket, rather than continue to pack it down into the rails like some older chains do.
    I’ve never done it either
