Helping a neighbor
Discussion in 'The Wood Pile' started by Skier76, Sep 25, 2022.
  1. Skier76
    Skier76
    CT and SoVT
    Our neighbors asked if I could help them by cutting s branch off a birch tree in their back yard. The branch was really leaning and despite their best effort, they weren’t able to get it to straighten out.
    No problem! This is one of those jobs were it’ll take longer to get all the gear, walk it over, set up than it will to cut.
    Until….you go too deep on your relief cut! I tried wedges, a pry bar and all that with my neighbor pulling on a rope they had attached to, the branch. Nothing worked.
    What did work: Removing the bar, installing my 16” bar and chain (which was slightly sharper than a butter knife) and finishing the cut.
    Once the branch was down, I put the 18” bar and chain on and limbed and bucked it. They’ll actually have a few nice smaller splits from this for their stove or fire pit.
    So the job got done, albeit a lot slower than anticipated. But we had some good laughs and I’m sure they’ll remember this one for awhile.
  2. buZZsaw BRAD
    Some FHC improvisation there Glenn. Way to get it done! :thumbs:
  3. The Wood Wolverine
    Good that you were able to remove the bar from the saw and tree to swap it out!
  4. Skier76
    Skier76
    CT and SoVT
    Thanks guys! Tried everything first and then arrived at taking the saw apart. First time I did that with the saw 6’ off the ground!
    LCBug, In the Pines, Chvymn99 and 4 others like this.
  5. GrJfer
    GrJfer
    The Woods of Arkansas
    Sometimes the easiest job turn out to be the ones that give you the most grief. Glad it all worked out in the end.
    Skier76, LCBug, In the Pines and 2 others like this.
  6. gwoods71
    gwoods71
    The Mitten
    This...
    Skier76 and In the Pines like this.
