pressure checking a Husky 372 xp.
Discussion in 'Chainsaws and Power Equipment' started by Mag Craft, Sep 14, 2022.
  1. Mag Craft
    I have been working on this 372xp and it acts like it has a bad air leak.
    I want to pressure check the crankcase and I can block the exhaust and impulse easy enough, but the intake is a little bit different on this saw.
    So, what do you guys use to block off the intake on these saws.
    Screwloose and M2theB like this.
  2. Nixon
    Nixon
    West Sunbury,Pa .
    If t’s an XP ( non XTorque ) , a piece , or two of gorilla tape on the carb mating surface ,punch a couple of holes through the tape with a hot scribe for the mount studs .
    If it’s an Xtorque …….. no idea . Never P&V’d one .
  3. The Wood Wolverine
    I use rubber from a piece of old inner tube from the motorcycle shop. I just cut to whatever shape is needed.
  4. Mag Craft
    It is an X-Torq.
  5. Mag Craft
    You cannot do that with this intake. It has a piece that protrudes out of the center of the intake.
    But I think I have an idea that I am going to use after thinking about it for a while.
    Keep the ideas coming you never know.
  6. M2theB
    M2theB
    Central Massachusetts
    I’ll look for a pic
    I did it on a Jonesered XT with a plug and a socket using the carb bridge and bolts
    MikeInMa and Screwloose like this.
  7. Mag Craft
    That is what I am going to use. I have a socket that I modified a little that will fit and block off plate for the end of the socket with a piece of rubber. I will use the carb screws.
    To get pressure into the crankcase I will use an old spark plug I modified years ago.
    Thanks M2theB
  8. M2theB
    M2theB
    couldnt find the pic, but you got the idea.
    Pic is here on the Bench thread, or OPE or both.
    Screwloose and Mag Craft like this.
  9. M2theB
    M2theB
    found it
  10. Mag Craft
    Yep thanks for the pic. That basically the same thing I have going on except I have a steel block off plate on the end.
    M2theB likes this.
  11. Mrxlh
    Mrxlh
    Dat Boot
    Have your limiter caps “fallen out” yet? The XT is very picky on carb tuning, mine acted the same way until I got it tuned correctly. Spike 60 I think is the fella here who had a great tutorial how to adjust the low jet correctly.
    M2theB and BuckthornBonnie like this.
  12. Mrxlh
    Mrxlh
    Dat Boot
    I swore up and down it was an air leak, sprayed everywhere a leak could occur with carb cleaner running, yet nothing. Stumbled upon the way to tune the low jet, and no more issues.
  13. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    On these saws-
    Check the throttle cable.
    Check the bearings and pto seal area.
    The carbs can be finicky but shouldn’t race.
    I do the spray tests on any that have running issues. I have pressure/vacuum tested one Xtorq and had to fab something up to get a seal.
    Mag Craft likes this.
  14. M2theB
    M2theB
    i had a surge issue at idle for this XT.
    Had to fatten it up to drive it out.
    Not sure I have cared at the expense of a good transfer to high
    MikeInMa likes this.
  15. Mag Craft
    Well, I am not ruling out the carburetor, but it is brand new. I need to do a pressure check on it. I do not want to be guessing at this point and need to start eliminating things I know for sure are either good or bad.
    Someone has worked on this saw before me, and they replaced the crank seals the carburetor and the intake boot. It has new fuel lines and filter and a new plug in it.
    But I do not think they ever did a pressure check on the saw. So, I have already tried tuning the carb with no luck and I do know how to tune a saw I have done plenty of them, but I have never had a need to pressure check a 372 xp and instead of trying to invent the wheel I thought I would see what you guys who done a 372 xp have used.
    So, when I go back into town on Monday, I will check this saw and keep you all updated. It will be interesting to see what I have found.
    I did check the cylinder bolts also. I already tore the carb apart to make sure no gaskets were in wrong. The guy who worked on this before me was a real dummy. I have ten items at a small family business that need to be looked at that have been worked on but not fixed.
    hotshot, Nixon, M2theB and 2 others like this.
  16. Mag Craft
    No problems with limiter caps it is a brand-new carb.
    M2theB likes this.
  17. Mag Craft
    The throttle cable is something I did not examine real close. I will check that.
    M2theB likes this.
  18. Mrxlh
    Mrxlh
    Dat Boot
    Then you indeed have a problem, meaning the limiter caps are still there. You cannot fatten up the low jet enough without a dealer screw driver to tune it without removing them. There is a super fine line of lean to too rich, the jist of it is you tune it as close as you can. Leave it idle and then tip it forward bar down at a 45 if it revs up, it’s too rich just lean it out a 16th of a turn in til it stops reving up.
    MikeInMa and M2theB like this.
  19. Mag Craft
    I do have a tool for adjusting the carb or as you put it the dealer screw driver.
    Getting it to idle at a low rpm is part of the issue. If the idle goes up when you tip it up after sitting, then it sounds like pooling of fuel from being too rich.
    M2theB likes this.
  20. Mag Craft
    Well, I went into town today with my socket in hand and did the pressure check on the 372xp. I tried pumping it up with my hand pump and it would not even come close to building up any kind of pressure. So, I hooked up a compressor and would blow in small amounts of air quickly.
    Finally found the base gasket for the cylinder on the clutch side right below the transfer port blowing air out like crazy. I am surprised this thing even ran.
    A new gasket is on order, and I will go back in on Thursday and replace the gasket and maybe add a little Yamabond while I am at it.
    Then perform another pressure check to make sure everything else is ok.
    I also found the screws that hold the oiler in place go right into the crankcase because I could see air coming from there too. So I may put some sealer on those screws too when I put them back in.
    I checked the cylinder bolts, and they were all tight so I never would have guessed it was leaking air from the base gasket unless someone before me screwed around with it.
