Oil mixtures and thoughts
Discussion in 'Chainsaws and Power Equipment' started by WeldrDave, Sep 10, 2022.
  1. WeldrDave
    Well, the moment we've all been waiting for, the response from Stihl! See below.
    Dear Mr. C-----,
    Thank you for contacting us at STIHL Customer Service.
    Regarding your inquiry about your STIHL 020 T, we would like to kindly inform you that the engine is certified to operate on unleaded gasoline and quality two-stroke engine oil, with the mix ratio 50:1.
    Additionally, we would like to provide you with the owner's instruction manual of the chainsaw, for more information on the fuel mix, page 20:
    https://cdnassets.stihlusa.com/1625858226-stihl020twithsafetymanual.pdf
    Should you require any additional information or assistance, please do not hesitate to reach out to us at all times, as we always remain at your disposal.
    Kind regards,
    STIHL Inc.
    536 Viking Drive
    VIRGINIA BEACH, VA 23452
    USA
    1-800-467-8445
    www.stihlusa.com
  2. Chud
    Chud
    I think way too much thinking goes into the mix oil topic, especially for firewood use saws.
    I’ve been in the tree work industry most of my life where saws are used daily on 50:1 with crap gas and chips/dust constantly falling in both reservoirs when filled. They are ran with less than optimal chain sharpness. Saws and filters are rarely cleaned, sometimes never and the saws last. Surely the manufacturers build pro saws for the abuse. I’d say the #1 saw killer for tree workers is the occasional cabbage that straight gasses, drops from the tree, or bucket, or backs a truck over it. As long as I can remember we have used Stihl platinum 50:1 at work in all the 2cycle ope. Other stuff gets broken or worn out before the engine fails.
    I’d say an occasional use pro saw mixed at 50:1 and with an owner that regularly cleans and replaces filters should last a lifetime. Maybe 40 and 32:1 gets a couple lifetimes and beyond?
    I take better care of my personal saws and expect saws that I purchased new to outlive me.
    I have used several kinds of mix, currently Stihl Platinum at 44:1 or around there. I will use other mix at the same ratio and never worry about it, because I’ll clean the saw and air filter, keep the chain sharp, and brush debris away from the fuel cap sometimes.
    40:1 Dominator mix in my XS saw, because that’s what Kevin recommended. :saw:
    My friend Jeff has been doing tree work a lot longer than me and has never had a saw blow up. Waiting for an answer on his mix ratio.
    Is the mix conversation more important for modified saws since they are operating outside of manufacturers r&d?
  3. clemsonfor
    Not a surprise that they now say "a quality two stroke oil" and took away the "if you don't use Stihl oil run it at 25:1"
    I knew they would say to run it at 50:1.
  4. WeldrDave
    I really commend this comment and have faith in it for a reason; I have beat the snot out of some of my personal saws, ran them for days and used the same mix that I will guess is about 40:1 because I always hit the mixture heavy with oil, I always have. I'm just a firewood guy, not a Pro in the field and only have had 1 problem when I lent out a saw to a friend, a (farm Boss) and he gave it to his kid who ran straight gas through it. :headbang: Even then, it wasn't stuck but the cylinder and piston were beat!!! I'd like to keep hearing more on this because it's good learning and I take (nothing) for granted. With that said, I also believe some preventative maintenance goes a long way as well. :yes:
  5. clemsonfor
    I was watching Bucking Billy and he recently did a video on oils. He said years he ran Castrol. And was saying it was the Stihl oil I believe...I think that's the one he said. I can't remember now but thinking I remember that right. He said it looks and smells the exact same then even shows you the back of the bottle of the name brand that says bottled by Castrol. He said he uses Castrol. I forget what ratio he said if he even said. He runs lots of vintage stuff...even ported vintage.
  6. clemsonfor
    I will echo what he said. I am a Forester and my main duty is timber sales. While not many saws are used these days, they still use them to trim trucks and sometimes for poles or storm damage is the heavy use that I see these days. But when I started out just a little over 15 years ago there was still lots of ground guys working and even some guys that bucked everything by saw, one even felled everything for a few years I was around with saws. They do beat their saws, they hardly get filters cleaned run hard for hours a day at 100F in the summers here. Ride around in a truck in the rain, and yes those guys get more dirt into the reservoirs than you could believe.
    Now I have seen them scratch pistons etc I don't hear about them blowing them up often. Some use Stihl oil they buy by the case, some use whatever they get at the gas station, others use whatever they bought by the case cheap.
  7. WeldrDave
    Like I said earlier, I/we used the pennzoil (outdoor), mostly all we could get, at 50:1 for years as a kid in that old Homelite XL we had and that thing cut many, many of cord of wood. It did eventually give up the Ghost, lost power and went bang but we put severel years of punishment on that little saw. We got every dime out of it, My old Man bought that in W.T. Grants store as I remember. $79.00 I think! o_O That would have been about 1972.
  8. The Wood Wolverine
    Not trying to make you feel old or anything.. that’s the year I was born! :whistle::zip:
    :doh:
    Screwloose, Ron T and WeldrDave like this.
  9. clemsonfor
    Not trying to make you feel old but that's 10 years before I was born!:doh:
  10. The Wood Wolverine
    :BrianK: Doh! I bought a Teeter inversion table a couple weeks ago. Enjoy “it” while you can. I didn’t have much care at 40 and not exactly sure where it started going south, but it did. :(
  11. Eggshooterist
    Eggshooterist
    Erff
    Definitely true. Lol. Myself included.
    Really, the major reason I'm running 25:1 is I'm trying to have one mix for all and I have a high performance 1/5 scale rc car that requires 25:1 according to the engine manufacturer, which is Zenoah / Husqvarna. An engine that can turn 20,000 rpm needs all the oil it can get. So far, running that mix in my saws has had no bad tuning effects or power issues so everything gets it. Even my hand held leaf blower, which by the way, picked up 100 rpm on top at WOT, after retuning, over the same fuel and oil at 40:1.
    The second reason is left over residue for long periods between usage. I have 13 saws and don't burn wood except back yard fires. 25:1 leaves lots of oil behind and it makes me feel more gooder despite having never had issues at 40:1 during storage with any oil. Lol
    Screwloose, clemsonfor, Chud and 3 others like this.
  12. Eggshooterist
    Eggshooterist
    Erff
    I watched that vid. From what I remember he said the Stihl oil in Canada is made by Castrol or was. Then he used a castrol branded ope type oil till they stopped making it. After that he switched to Castrol Go full mineral bike oil, which is one of the 4 oils to make it through all my lean oil tests without engine damage. It good oil. I use it for break-in before switching to Dominator. Only downside I've seen is my smallest saws have tuning / running issues with it at the only ratio I've tried it at outside my testing, 32:1. I'd probably have to run 40-50:1 I think to alleviate the tuning issues.
  13. Eggshooterist
    Eggshooterist
    Erff
    Something to ponder....
    In another life, on another forum, there were guys from other countries that showed pictures of the manual from new saws sold there. Same models as here. Warranty VOID if using less oil than 40:1. I believe it was Australia but don't quote me. This was in the last 3 years. Their post mentioned they don't have an EPA type bureaucracy in their country. What does that tell you when the same manufacturer has the same model of saw in two different parts of the world and they recommended ratios are 50:1 here and 40:1 there....
  14. WeldrDave
    I was 10 then. :whistle: That little Homelite was our first "New" saw. We had an old Craftsman P.O.S. That had a thumb bar oiler and flooded out EVERY time you started it if it didn't fire off quick. :headbang::headbang::headbang::hair::hair::hair: I did all the saw work, my Father had arthritis in his back and hands, things were tough for him so I got well schooled by 10 years old with a saw. We had a family friend who owned a small farm, and I would help cut wood with him, (where I learned) saw manners.
    :rofl: :lol: You're a Pup Clem! :p I got my drivers license in 1979 :cool:
  15. SimonHS
    SimonHS
    Yorkshire, England
    Do you know if Castrol Go is renamed for overseas markets. I cannot find it in the UK. We have three flavours of Castrol Power1.
  16. WeldrDave
    :eek:o_O:jaw::bug: Ok! :salute::rofl: :lol:
  17. WeldrDave
    I know this to be true also. I did read that somewhere! :yes:
  18. WeldrDave
    Can you find what you want on Amazon?
  19. WeldrDave
    This is the Castrol (I) see on the shelves here from time to time. Our local NAPA auto parts store is limited on 2 cycle. If I drive 30 minutes I got a good oil selection from another store, and my Stihl dealer is 25 miles away. We have a Tractor supply now, opened last year. has Husky and other oils there also.
  20. Eggshooterist
    Eggshooterist
    Erff
    Yeah, i have issues. This is down from 30 ish saws in my possession simultaneously. Ive had 50+ in the last 3-4 years.
    Screwloose, clemsonfor and WeldrDave like this.
