A small haul of hickory and a whole lot of nuts
Discussion in 'The Wood Pile' started by Eric Wanderweg, Sep 11, 2022.
  1. buZZsaw BRAD
    Suuuuuuuure you were! ;) Is grabbing a log considered an errand? It is if you're a FHC member!
    Or is an "errand" a way to get it by the Mrs? Any "errands" to do tomorrow???
    "Ill be back shortly honey, i have an errand to run"
    "Then why are you taking your chain saw"? :rofl: :lol:
  2. The Wood Wolverine
    Season and burn that and you'll be changing your sig line to looking for more SBH... :dex:
  3. buZZsaw BRAD
    He likes elm too Jason! Wonder which he likes more? How about it Eric???
  4. Eric Wanderweg
    In The Wood Wolverine ’s honor I’m going to fire up a mixed load of elm AND hickory on the first frigid day this winter ;)
    If I had to pick just one, it would be hickory over elm. BUT… I seem to come across more elm than hickory and my stacks definitely reflect that.
  5. The Wood Wolverine
    If he burned enough of the 2, there is one clear winner. SBH has MUCH more BTU's per cord. There really is no contest here.
  6. brenndatomu
    Same...shaggy beats everything else I've used...Locust left me disappointed...not that its bad, just didn't live up to the hype...and the shaggy overperformed from the charts.
  7. Eric Wanderweg
    Luckily I have a few stove loads of Shagbark to burn this year. Not a lot obviously but enough to get a better feel for the stuff. This stack is under my deck and I should be getting to the bottom third (top 2/3 is all red maple) sometime in December.
  8. buZZsaw BRAD
    Im wondering if there is a big btu difference between green fresh cut BL and the long down/dead "petrified" BL that Eric VW speaks of often. I notice a difference in the density.
    Im in no way knocking SBH as ill take it when i can and a scarce score for me.
  9. buZZsaw BRAD
    NICE! How many years dried? Should i hope for a frigid December?
  10. Eric Wanderweg
    This was a tree that came down next door to me during Isaias in August 2020. I split it on the thin side to dry it faster, so it should be good to go at over 2 years in my stacks.
  11. brenndatomu
    I've burnt old fenceposts, so about as petrified as it gets...never tried fresh cut
  12. buZZsaw BRAD
    I think so. Have you put a MM to it?
    Geez, two plus years already! :picard: Still lots of down BL "hiding" around here from that storm and the tornado later that month.
  13. Eric Wanderweg
    I just finished splitting what I got so far. Looks to be a few cold days worth of heat :thumbs: It’s only stacked in a temporary location for the time being. Once I drop a load of wood off to my brother-in-law, I’ll have room under cover for this hickory.
  14. SimonHS
    SimonHS
    Yorkshire, England
    You need a 'beater' truck saw, so that this never happens again.
  15. Eric Wanderweg
    I concur 100% :handshake:
    My Echo CS-370 with the 16” bar does well in that role.
  16. T.Jeff Veal
    That's a nice score. What I found that works great on the vines is a pair of loppers. Doesn't sling juice anywhere, you can cut vine, grab it with loppers and pull it off. Then cut logs. Lots of it on those oaks we are cutting.
  17. Cash Larue
    Cash Larue
    Pine, CO
    Nice score! Never seen a hickory tree that I am aware of.
  18. Eric Wanderweg
    I went back to this score hoping to fill up on the rest of this hickory and the large ash that was on the ground there. Just about all of it was gone! I did manage to buck a few small hickory rounds, and scooped up some limb wood a little further down the road. There was more ash further into the woods, but after several test cuts I could see it was getting too punky. Oh well, a few hickory crumbs is better than nothing. While I was out this afternoon with the kids, I also managed to get a bunch more black walnuts too :thumbs:
    Yawner, MikeInMa, SimonHS and 9 others like this.
  19. T.Jeff Veal
    Wish more had been there for you...:(:(
    buZZsaw BRAD and Eric Wanderweg like this.
  20. Eric Wanderweg
    This is how it’s been for me this entire year, a little here, a little there…Today was supposed to be a heaping truckload, but it wasn’t in the cards I guess. I think I know who got it though. A coworker of mine lives a quarter mile away from this spot and he was telling me last week about scrounging along that road. I’m just glad it’s going to heat someone’s home and not rot down in a ditch.
