660 gas tank leak
Discussion in 'Chainsaws and Power Equipment' started by Dakota Hoarder, Sep 5, 2022.
  1. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    I was using my 660 today noodling some uglies. Everything was working fine, then suddenly stalled. Was able to restart then a small fire started around the gas tank. I got it out and invested. I found the spark plug had puked from the cylinder, I figured that was the problem, so replaced it and attempted to start the saw, no go.
    Upon further investigation I noticed a slow gas leak between the gas tank and orange part of the saw along the seam. A very small amount of gas slow builds up along the seam. would this be the problem? And what’s the solution?
    M2theB and Screwloose like this.
  2. Chud
    Chud
    Is the tank vent leaking?
    JimBear, M2theB, Screwloose and 2 others like this.
  3. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Possible, how do you check the tank vent for leaks?
  4. Chud
    Chud
    If it doesn’t leak when placed bottom side down and does leak when the saw is on it’s side, than it’s probably the vent. Is it an aftermarket tank on your saw? On my 044 I can see the tank vent when the air filter cover is off.
  5. M2theB
    M2theB
    Central Massachusetts
    im more curious about the spark plug coming out
    Screwloose and Ron T like this.
  6. buZZsaw BRAD
    May have to invest in a new tank? :D
    Screwloose and Chud like this.
  7. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Appears to be the tank vent. I set the saw on its side a it started dropping right away.
    so do I just need to replace the tank vent?
    Screwloose likes this.
  8. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Chud any suggestions on changing the vent? Just don’t want to pull it to hard a break something
  9. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    So no problem getting the tank vent off. After looking for a replacement vent online I see that it is missing the white part of the vent which I’m assuming is the valve that keeps it from leaking gas. Not sure how that could have went missing, or if it’s been gone since I’ve had it and never caused a problem. [​IMG]
    Chud and Screwloose like this.
  10. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    Are after market tank vents OK or should I check with my dealer for OEM?
    Screwloose and JimBear like this.
  11. JimBear
    JimBear
    I would just go with oem unless the price is astronomical or not available.
    Chud, Screwloose and Dakota Hoarder like this.
  12. Dakota Hoarder
    Dakota Hoarder
    Sioux Falls, SD
    For sure, just thinking if it’s not available. I can’t imagine an ORM would be over $20 if the dealer has one.
  13. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    1122 tank vents have changed throughout the series. If you have the 660 style that fits the grommet, go with an oem replacement.
    If you have the earlier style with the 064 type grub screw (unlikely), then the AM Echo-type are an improvement.
    You can fit the Echo type on a lot of saws with slight modifications and some fuel line. Rarely… say 1/20, I’ve seen an AM Echo vent not work out of the package. They last a while despite having rubber components inside that plastic housing.
    Dakota Hoarder likes this.
  14. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    The AM vents around with the grommet (your pic) are basically the Echo style. I would wonder how well the grommet will seal after long term exposure to gas. All cheap AM fuel hoses will eventually fail, in my experience. They’re lacking something in the chemistry of the rubber.
    Chud and Dakota Hoarder like this.
