How many gallons of mix do you go through each year?
Discussion in 'Chainsaws and Power Equipment' started by WESF, Aug 30, 2022.
How many gallons annually?
  1. Less than 1
    0 vote(s)
    0.0%
  2. 1-3
    8 vote(s)
    20.0%
  3. 4-6
    9 vote(s)
    22.5%
  4. 7-10
    5 vote(s)
    12.5%
  5. 11-15
    9 vote(s)
    22.5%
  6. 16-20
    4 vote(s)
    10.0%
  7. 21+
    5 vote(s)
    12.5%
  1. Mag Craft
    About 4 gallons a year. It does not matter what the ratio is that is how much mix I use.
  2. clemsonfor
    I understand the 87 vs 91 octane thing in a normal engine and in a saw. Some don't and can't buy yea I know what your saying I use 87 for the same reason. And yes not my attention to have an octane/ethonol/ oil debate either. Use what you want on YOUR saw. On my saw j use MY MIX and my MIX ONLY!
  3. clemsonfor
    Red Armor is Echo brand factory oil, buy it at your Echo dealer or like me you have a dealer that only wants to sell you little bottles or a case of 4 gallon jugs just watch it on Amazon and buy it when it's at a good price.
  4. clemsonfor
    I don't really like red dye oil cause gas jugs are red and it's sometimes hard to tell. I like blue better for this reason.
    MAF143 and Screwloose like this.
  5. clemsonfor
    Haha , yea but the question was "How many gallons of 50:1 mix do you use". I see it has now been edited or changed to no longer say that.
    Edit: Well I see his post still says 50:1. To be honest I didn't see the poll thing till I answered and scrolled to the top but I thought it said the same thing maybe it didn't.
  6. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Cool about the red armor.
    Good to know.
    I have some Husqvarna 2 cycle kicking around...I bought a bit when I first got into cutting, and I think someone gave me some (husband died or something), and then a friend bought me a gallon jug of the stuff (Husqvarna). If I use a quart a year of the 2 cycle (for 10 to 12G/yr) I'm set for a few years I reckon.
    Sca
  7. Will C
    Will C
    New York
    I but a 6 pack of mix oil in the fall and another in the spring. In the 11-15 gallon group. Saw work, I do a lot of weed eating, and about a gallon of mix in the leaf blower.
  8. WeldrDave
    I'm right about 4+ gallons a year. I didn't include my leaf blower and I only use that maybe 10 minutes every lawn cutting. between my saws and the weed whacker I'm a good 4 gallons. I'm a big Lucas 2 stroke oil fan. Have had GREAT luck with this oil, I've put some hard hours on a couple saws, Jug and piston looks like new in my 029 Supers...
    Mag Craft and Screwloose like this.
  9. Mag Craft
    The title says nothing about the ratio but when you read his post it does mention 50-1. But the question is still about how much 2 cycle fuel do you use in a year.
    I would never use 50 to 1 mix. I think that is just EPA misinformation and it is not good for a lot of 2 stroke engines.
  10. WESF
    WESF
    MN
    Do you guys think oil goes bad in a reasonable amount of time?
    I have some sealed little Echo bottle in the shed from 10 years or so ago. Still good?
    Sirchopsalot likes this.
  11. clemsonfor
    10 years no I don't think it's bad. I would sked it really good if it were me me and then use it. That's also still a modern oil in that many years. Now if it were 35 years old I probably would use it in my diesel fuel for the tractor as a mix to help lube the injection pump at like 250:1 or something. In that time oil technology has improved and for the age and the cost of stuff I don't think it would be worth $6-20 worth of two stroke oil.
    WESF likes this.
  12. Sirchopsalot
    Sirchopsalot
    medium city in CT
    Im zero expert, I dont think motor oil goes bad or rancid. I gould see some of the addatives separating perhaps, maybe.
    I'll shake my jugs before pouring, and if it doesn't look right, I'll bring it to the farm for tractor/excavator use and clemsonfor said.
    MikeInMa likes this.
  13. clemsonfor
    Your correct it doesn't go bad, but it can separate out, and not being a chemist or tribologist I am not sure if there is a process to get some of the additives to suspend in the solution that is beyond just shaking the jug.
  14. clemsonfor
    I know I mentioned it. But not sure if we count boat mix gas? But anyway like I said we boat but I don't use a ton of fuel every year. But I use about a gallon of TWC3 oil a year.
  15. Fanatical1
    Fanatical1
    Pretty close to 12 gal of premix every year for the saws, blower and string trimmer….i know because I refill 12 of the one gallon Stihl oil bottles every fall from my gallon jug of oil to try to save a couple bucks. :whistle:
  16. Ronaldo
    Ronaldo
    I probably use around 10 gallons of mix in a year. I do far more cutting in the fall and throughout the winter, dont like cutting in the heat.
    WESF likes this.
  17. Dok440
    Dok440
    NorCal
    Cutting season through weed eating season I went through 15gal which I mixed myself. After that I switched to the Husky fuel or Red Armor 1 gal cans because it lasts longer. I go through two or three gal of the expensive stuff.
    WESF likes this.
  18. James Miller
    James Miller
    Hanover PA
    I choose 7-10. Normally go through 2 of the bottles that are good for 5 gallons of mix. This will probably go up though as the 2095 I picked up this year is a thirsty old girl.
  19. buZZsaw BRAD
    I make two gallons at a time. Stihl 40:1 silver bottle. I used to write a date on the gas can when i filled it. Averaged out to six weeks per two gallons. Havent done that in recent months though. 16-20 gallons. Includes what i use in my handheld leaf blower.
    Sirchopsalot and Mag Craft like this.
