Made my own fire fuel
Discussion in 'The DIY Room' started by The Wood Wolverine, Sep 27, 2021.
  1. The Wood Wolverine
    Started burning some of these this evening.
    5:35
    7:00
    7:54
  2. The Wood Wolverine
    Next round is 10 of them. 7:55
  3. buZZsaw BRAD
  4. metalcuttr
    metalcuttr
    western WA
    I wonder if there is a way to add Elm sawdust into this product to boost it's appeal. Interesting thread actually!
  5. TurboDiesel
    That's some funny chit right there:handshake:
  6. metalcuttr
    metalcuttr
    western WA
    Seriously?o_O:picard::hair::headbang:
  7. buZZsaw BRAD
    Funny you say that as i was thinking black locust chips. Maybe we can get Jason to give it a try.
  8. Nitrodave
    Nitrodave
    Grayling Mi.
    I’m sorry. :(
  9. The Wood Wolverine
    Zero from the last one, 3-5" predicted. It's snowing at 1/4 an hour rate and is supposed to continue till morning.
    Ya know, if I had a bunch of saw chip or noodles, I wood definitely add them to these bricks!
    Heat output is good but boy are they laying down the ash! And the smell is not desirable.
    Opened the door a sec and tried to melt my phone!
    And unfortunately my glass isn't squeaky clean.
    Opened the drafts for this vid. Sorry about the soundtrack.
  10. The Wood Wolverine
    I raffed!
  11. metalcuttr
    metalcuttr
    western WA
    Nope, not believing it!:confused:
  12. The Wood Wolverine
    Another firebox full of bricks.
  13. TurboDiesel
  14. The Wood Wolverine
    That pic they were 2 deep and lasted about 3 hours.
  15. The Wood Wolverine
    Bump.
    Getting ready to shut down an interlock shop and had to shred some paperwork, so I kept it.
    Started leaking some around this handle. Oh well. Hoping it self seals.
    Letting this soak a few days. I plan to use 5 gallon buckets and my splitter to press water out. Stay tuned..
    Cash Larue, jmb6420, FatBoy85 and 5 others like this.
  16. buZZsaw BRAD
    Cool. An annual FHC tradition. I think you should try making one out of noodles just for the heck of it.
    Cash Larue, jmb6420, FatBoy85 and 2 others like this.
  17. The Wood Wolverine
    I'd love to add sawdust/noodles as filler. I just don't have any right now. So when the paper breaks down, it can be pressed into any shape. I'm not sure, but I'd guess noodles themselves wouldn't stay compact.
    Cash Larue, jmb6420, FatBoy85 and 3 others like this.
  18. chris
    The noodles will due to the moisture of the paper left after compression. if you need more sticky effect ground up oat meal , rice, patatoes , corn basicly any heavy starch will work as a binder agent. The paper would also if ground fine, instead of just strips.
    Cash Larue, jmb6420, FatBoy85 and 4 others like this.
  19. The Wood Wolverine
    I meant just noodles, no additive. I don't think they'd stay compact. Added to my slurry, absolutely.
  20. The Wood Wolverine
    Had the time today.
    Drilled up a smaller bucket that alread had a small crack.
    And I finally found a reason to have the splitter vertical.
    Used a cookie and a piece of 4x4 for a press. 6066B505-229F-4009-871F-6F49B4FE2B08.jpeg
    After about the second or third puck, the crack in the bucket totally blew out.
    So I had to use another bucket.
    What I did was cut the bottom off of another one with about 3” of lip. Drilled that out and placed it on top of the slurry, cookie in that and then 4x4. The wood left too much gap and the paper was shooting up and out. The small piece of bucket had closer tolerance and helped with the issue.
    Was not able to really press water out. Buckets started making noises so overall, I’d call this setup a flop. Won’t do it again.
    Cash Larue, jmb6420, FatBoy85 and 8 others like this.
