Anyone use an old storage shed for wood?
Discussion in 'The Wood Pile' started by Geoff C, Jul 28, 2022.
  1. Geoff C
    Geoff C
    NEPA
    There’s a guy on Facebook selling traded in storage sheds. Just your regular old 2x4 T-111 siding with a double door.
    He has a 12x16 for $1000. I was thinking the lumber to build a wood shed would probably cost that much and I could probably jam 5 cord in there, already seasoned or add some vents.
  2. Geoff C
    Geoff C
    NEPA
  3. MikeInMa
    You'd need to alter it to allow for air circulation.
    Not a bad idea, however.
  4. buZZsaw BRAD
    Take the front and back off for good air flow (maybe face it into the prevailing wind) and cover them in the cold weather sort of what M2theB does with his. The front could always be kept open all year.
    I have an old tree fort (size of a small shed with a low ceiling) (its no longer in the tree either) that i utilized for wood storage. I got a lot of free wood from the homeowner in years past. He had several trees taken down in May of last year and let me keep the wood there. Its right next door to where i store wood now.
    Have you looked on CL/FBM for buildings. Usually very cheap even free if you haul away. I think JiminyKicket got one that way. Also old deck demo salvaged boards can be found for free as well.
  5. Christoph
    Christoph
    SW Colorado
    I use mine. I load it up every fall with wood for that winter. Since it's already seasoned and ready to burn I stack it in tight. Its the best place I have to keep the wood out of the snow.. mostly burn pine but some hardwood at night, so I stack about 1/4 of each row hardwood. 20210824_192351.jpg
  6. buZZsaw BRAD
    Just curious as to what species of hardwood you get out there Christoph?
  7. JimBear
    JimBear
    If it’s already seasoned, I wouldn’t worry about air flow, that shed looks like it has a window in it also, most of them have some sort of air vents anyway.
    The only problem is could foresee is maybe too much weight for the flooring material & breaking thru. I would check the floor joist spacing. If that is a concern put pallets down so you don’t have a pile of splits between two floor joists.
  8. JiminyKicket
    JiminyKicket
    Seattle
    I regret my experience taking down a much smaller, simpler shed, and it was free! Unless one of you has the equipment and knowledge on moving a structure that size, you’ll need to carefully disassemble it to moveable sizes. If it’s a shingled roof it’s practically unusable due to weight.
    There are some great videos online about building sheds on the cheap—I’d aim for that instead. But either way good luck and let us know where you landed!
  9. sirbuildalot
    sirbuildalot
    Mass
    Just a word of caution. Most of those pre-fab sheds aren't built very heavy duty. Often only having 2x4 or 2x6 floors. 5 cords of wood could be up to 25-30k lbs if green.
  10. Backwoods Savage
    It will work with only slight modification. How will it be moved?
  11. theburtman
    theburtman
    I built my woodshed by using the roof from an old metal storage shed supported by 4x4 posts and 2x6 frame. Holds 4 cords.
  12. Eckie
    Eckie
    Man why can't I find a deal like that?? I would think if he has them sitting in a lot like that, he probably has a way to move/ deliver them. But personally I would use them as a shed, I would have much better use for one other than wood storage inside. Maybe put a lean-to off the back and/or sides and use that for other storage, including firewood.
  13. Ron T
    Ron T
    Northeast Ohio....Bowdil
    That's cheap for a shed that size around here.
  14. SimonHS
    SimonHS
    Yorkshire, England
    ^^^^^ This is the best answer. Maximum airflow to season the wood AND a nice dry space to keep more stuff in.
  15. wood and coal burner
    Quakertown,PA
    Mine is an old farm shed. I added a door on the back and screen windows on the side. The door makes it easy to pull out the longest seasoned wood first. This way I can be filling it up with just split wood while emptying at the same time. Cannot see the doors but there is one on the left and another on the right. You can see the window. Woodshed.jpg
  16. JiminyKicket
    JiminyKicket
    Seattle
    It’s impressive how you’re using every square inch! If someone opened the little birdhouse on the right, would they find an ugly or two? :rofl: :lol:
  17. Geoff C
    Geoff C
    NEPA
    the guy said he’d deliver for $300.
    it’s a shed dealer. They give you a few bucks off a new one to “trade in” your old one
    JimBear, Cash Larue, SimonHS and 2 others like this.
  18. Christoph
    Christoph
    SW Colorado
    I have western juniper , it’s similar to cedar. Also some gamble oak
    buZZsaw BRAD likes this.
  19. buZZsaw BRAD
    Ive heard that gamble oak is some dense stuff and great firewood.
    Christoph likes this.
  20. DNH
    DNH
    Missouri
    No that’s where he keeps his fire starter.
    JiminyKicket and LCBug like this.
