Tractor mods or accessories
Discussion in 'Chainsaws and Power Equipment' started by old iron, Jul 12, 2022.
  1. mike bayerl
    mike bayerl
    Yellow arrow is where the valves and solenoid are tucked in behind the FEL. It's not OEM (not available), but is is and excellent aftermarket unit I picked up from Messick's. Everything came in the kit and was very well designed to fit my specific tractor and FEL. Would highly recommend.
  2. mike bayerl
    mike bayerl
    Meh. I don't use my grapple as much as I use my bucket or pallet forks. But there are definitely some jobs that is it 100% the right tool for and then I am thankful.
    Screwloose and Chvymn99 like this.
  3. yooperdave
    Thought you were going to say "I added a louder horn to my tractor!"
  4. Canadian border VT
    Thanks mike bayerl looks factory.. I need to add SSQA first saving dollars waiting for my welder rotator cuff to heal.. which is ok since it’s still back ordered
    mike bayerl, Screwloose and eatonpcat like this.
  5. Screwloose
    This is my counterweight. I set the box in a kiddie pool of water and poured 900ish pounds of lead in the bottom. A steel plate covers the lead leaving the rest of the box for storage. Spacers and a frame mount the compressor. Handy to have for blowing out saws and stuff off yourself. Plus it helps cool you off, especially with a splash of water.
  6. Screwloose
    I always meant to put a horn on the tractor.
    Younger days had a real train horn on a jeep. Could tell some stories......
  7. brenndatomu
    Had one on my jacked up 1980 F150 stepside too...boy would that get some attention downtown between the tall buildings! :whistle: :rofl: :lol:
    I was always amazed how long a small tank of air would last...I just had an air brake tank off an L series Ford truck mounted up on the spare tire rack
  8. Screwloose
    Used to have to stop and look at the rr crossings. Just when the person in front of you was on the tracks........
  9. GrJfer
    GrJfer
    The Woods of Arkansas
    Awesome idea on the air compressor. I may just add an air tank to my carry all design when I build it.
    Did you smelt the lead in ballast box?
  10. mike bayerl
    mike bayerl
    Good plan, SSQA is WAYYYY more useful than 3rd function.
    eatonpcat and Chvymn99 like this.
  11. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Opinions vary ;)
    T.Jeff Veal, Chvymn99 and eatonpcat like this.
  12. mike bayerl
    mike bayerl
    No use for a 3rd function if you have a pin-on bucket on your FEL.
  13. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I see your insisting that your opinion be correct..so I'm gonna leave it at that. Enjoy !
  14. GrJfer
    GrJfer
    Main reason I went with the tractor did over their smaller less expensive model. Now I just need to get more proficient at removing my pallet forks, as I struggle verses removing the bucket.
    T.Jeff Veal, Chvymn99 and HoneyFuzz like this.
  15. eatonpcat
    You boyz will argue about anything...lol
  16. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I give up pretty quick anymore ! My world is different than the next guys and so on....
  17. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    I remember the old days where everything was pin on.
    You will get great at it in no time !
    Having the pin on always made me think more ..cuz I didn't want to change over all the time lol
  18. GrJfer
    GrJfer
    I bet! SSQA is so easy I can't imagine dealing with a pin on.
  19. Screwloose
    I melted it a cast iron pan on a turkey burner. The box was leveled and the water kept the paint from burning. Took all day, a long day. Not a continuous pour but basically a series of stuck together "sheets "
    T.Jeff Veal, walt, Chvymn99 and 2 others like this.
  20. sirbuildalot
    sirbuildalot
    Mass
    I agree 100%
    Chaz, GrJfer and Screwloose like this.
