Trailer side 4 pin flat wire connector pin corrosion!
Discussion in 'The DIY Room' started by don2222, Jul 20, 2022.
  1. don2222
    don2222
    Salem NH
    TurboDiesel and Screwloose like this.
  2. Screwloose
    Haven't tried a cover but nyk 77 will stop the corrosion from happening.
    TurboDiesel and don2222 like this.
  3. don2222
    don2222
    Salem NH
    Screwloose likes this.
  4. Screwloose
  5. don2222
    don2222
    Salem NH
    Maybe this conductive grease is better?
    I know dielectric grease is used in high voltage applications like spark plug boots to prevent arcing. It also keeps the contacts from corroding but in this low voltage application where conductivity can be a problem because the connection just breaks and the lights do not work. So conductive type grease with silver or carbon having conductivity may help a bit more??
  6. TurboDiesel
    Screenshot_20220720-143738_Chrome.jpg When i have trouble with trailer plugs i clean and fill the plug with this. If that doesn't work, i replace the plug and fill them with same.
    It works
    huskihl likes this.
  7. Warner
    Deoxit d5 is an excellent cleaner/ protector.
  8. don2222
    don2222
    Salem NH
    Try the conductive grease! It should work much better!!
    Nitrodave likes this.
  9. don2222
    don2222
    Salem NH
    I just ordered 80 grams like 2.58 OZ tube for my trailer wire connectors.
  10. don2222
    don2222
    Salem NH
    Hi TD
    Just got the Carbon Conductive Grease today and wire wheeled the connector pins to make them nice and shinny.
    So I will try this. It is black as coal because of the carbon. LOL However carbon conducts electricity so it should work well. We will see. :)
  11. corncob
    corncob
    Somewhere in Lower Michigan
    If it was mine, I'd ditch the flat connector and go with a round 7 pin male on the trailer and a 7 pin on the vehicle and keep the trailer connector greased up with di-electric grease. The female will come with a spring cap. I consider the flat connectors to be U-Haul esque.
    TurboDiesel likes this.
  12. TurboDiesel
    Yes!
    I change all mine to 7 round RV style connections.
    eatonpcat likes this.
  13. huskihl
    huskihl
    I’d think the carbon conductive grease would work when there is space between terminals. Not so much in this application where there will be grease touching all the terminals on the trailer side. It would definitely be bad news inside the vehicle end of a 7-way round.
    Use the stuff recommended above several times as it’s proven to work
  14. don2222
    don2222
    Salem NH
    Ok the 7 pin is different than my cheap 4 pin connector. Each pin is separated so no chance of shorting. When I plugged it in there must have been a gap because the right side blinker did not work. When I pulled the plug apart and then plugged it in again then it worked. So for the 4 pin connectors this may work better. :)
  15. don2222
    don2222
    Salem NH
    I also just cleaned the main ground connection. There was a tad bit of corrosion under the SS washer so I put the carbon conductive grease there too. That may help?
  16. brenndatomu
    Be careful with that carbon grease...handy stuff if used sparingly, but liberal use of it could easily cause a short, even with a 4 pin.
    Ask any industrial electrician how they feel about carbon tracking!
    In the Pines and eatonpcat like this.
  17. Semipro
    Semipro
    SW Virginia
    I've used Vasoline on connectors, battery posts, bulb bases/sockets, etc. for many years with success.
    I'd be concerned about shorts resulting from use of conductive grease.
    I've tested the voltage drop on connections where dielectric grease was used and not seen any significant resistance. Still using dielectric grease where I want conductivity seems wrong. Hence the Vasoline.
  18. don2222
    don2222
    Salem NH
    I agree about using non conductive dielectric grease. However the reason is that in 120 volt and higher applications there are no problems with conducting the electricity and keeps corrosion down. Since most of the work electricians do is in the voltage range that is all you see in electrical supply departments and stores. It works fine for that.
    However for LOW voltage applications where a little corrosion can make a difference with a much higher percentage of a voltage drop conductive grease is really needed!
    It seems like 12 volt DC automotive electrical applications the wiring is heavy and the voltage is high enough so either one works. I especially prefer the conductive grease on the trailer ground connections because that is a real trouble spot! However I did try it on the 4 pin connector and it seems to work well for me there too.
    Semipro likes this.
