Making the Right Stove decisions
Discussion in 'Modern EPA Stoves and Fireplaces' started by Old Nate, Jul 12, 2022.
  1. Old Nate
    Old Nate
    Western PA
    Throwing a hypothetical out there…
    If you could do it all over again, would you do things differently meaning changing hearth design, stove location, get an entirely different stove or maybe only change one of those above factors or would you stick with your exact same set-up, no regrets?
    I’m asking because I’m moving soon to a bigger house and while I’ve been happy with my Jotul F500 Oslo I’ve been thinking of some things I’d have maybe done differently if I could do it all over again (which I’m about to do) and want to make sure I make the best decisions in the coming months when it comes to stove choice, and design and on and on.
  2. Dok440
    Dok440
    NorCal
    Best thing we did when we bought this place a few years ago was to not put a stove in right away. Turns out the place we thought we wanted the stove is not where we finally decided to put it. It's now in the perfect spot, next to the stairwell, heats up most of the downstairs and sends heat upstairs as well. We put the stove in about a year after we moved in and ready for the next winter. I'm not saying you have to wait that long, but it might be good to get settled in the place before you make a decision.
    Brad
  3. Luke
    Luke
    Austin TX
    While choosing the right stove is important, operator knowledge and experience are also very important in avoiding problems.
    Backwoods Savage and theburtman like this.
  4. Canadian border VT
    Build hearth 16 inches higher so it’s easier!!
    gusty60, Stephiedoll, Jutt and 10 others like this.
  5. Old Nate
    Old Nate
    Western PA
    Yeah that’s not a bad idea. My current hearth sits about 8 inches off the ground and sometimes I wish it was higher!
  6. Warner
    This!
  7. SD Steve
    SD Steve
    South Dakota
    I didn't know a whole lot about wood stoves when I bought my first one. It's was cheap, only about $850 or so with delivery. Last winter my youngest son was cleaning out the ashes after the fire had gone out and he stabbed the poker right into and through upper panels that are like styrofoam putting a huge hole in one of them and breaking the other into 2 pieces. Looked online and followed some information from a couple guys on here. I settled on Drolet Escape 2100. Way bigger than my first stove. 20220207_181053.jpg
  8. ReelFaster
    ReelFaster
    S.Jersey
    Love my setup, but if had to so over and or was moving into a new place and putting in a stove I'd consider putting a cat in vs. my Drolet to get longer burn times and cut down on wood consumption. I know there trade offs but just something I'd consider.
  9. dirtdevil
    dirtdevil
    Northern central Indiana
    I, (strike that) we, love the Progress Hybrid. It heats the objects and walls rather than the air. Our upstairs is not blocked off/ open stairway and it stays cooler than the downstairs. Our stove is on an end wall of the house, the only thing I would change is try to position it in the center of the house if possible. By the way, if the living/dining room falls below 75* degrees during the day my wife thinks it's cold. If it's below 68* in the morning something isn't right and the stove needs looked at. LOL we are talking about a hundred and thirty year old brick farm house here... 1900 sq ft. Two story
  10. Old Nate
    Old Nate
    Western PA
    I hear that. My wife doesn’t accept any temp under 75 in the winter now. And with the new house we’re going from 1600 square feet to 2800 I’m worried I won’t be able to cook her out quite like I used to. The Oslo was plenty of stove for my old house but the new one, not sure what I’m going to go with.
  11. Marshel54
    Marshel54
    The one thing I would do different is raise the hearth. Backwoods Savage told me to raise it 1 foot when I built it. I didn't do it. I wish I would have followed his sage advice every time I empty the ash pan.
  12. Backwoods Savage
    Ours is 16" which is perfect for me sitting on a chair while loading the stove.
  13. Backwoods Savage
    We keep our home around 80 all winter.
    Stephiedoll and Chvymn99 like this.
  14. Backwoods Savage
    If I had it to do over again, I likely would do nothing different. We had wanted this stove for a long time but waited a long time because of finances. When we put it in we cussed for not getting it sooner even if we had to finance because we usually were cold all winter long. suddenly when we put this stove in, we were basking in warmth all winter.
    In addition, with the heat from the soapstone we no longer have to move the air to other rooms as they warm up just fine. We do have one ceiling fan which we run on low but that is all. The bathroom is quite a distance from the stove and we used to have to heat it with an electric heater before showering. That is no longer needed.
    I shudder thinking about some folks who will struggle with heating their homes this winter but smile every time I walk past one of our wood piles.
  15. Canadian border VT
    I built hearth before FHC… Dennis is still right:headbang:
    My wife chuckles at WWDD…
  16. WESF
    WESF
    MN
    We're heading into our fourth winter with an F400. Only regret is not getting an F500, or a Progress Hybrid.
    Backwoods Savage and Chvymn99 like this.
  17. Rich L
    Rich L
    Eastern Mass.
    If you have a moderately sized home a smaller stove will never do.
    WESF and Backwoods Savage like this.
  18. Jutt
    Jutt
    Bailey, CO
    First stove (in our first house) way back in 2009 was a 1.5cu ft insert. While it was infinitely better than the fireplace it was way too small.
    Next stove in the next house was an NC-30 and I loved that stove. The bigger firebox was definitely better. Put out lots of heat. But now I can’t find it or the 32-NC.
    Now I’m in yet another home waiting to install an Ashley 2500 (and the chimney through the roof and the hearth) that’s sitting in the garage. It was a good deal but I’m now considering an Ideal Steel.
    moresnow likes this.
  19. Sirchopsalot
    Sirchopsalot
    medium city in CT
    We jacked oir stove up about 12". I used some nicer looking pavers, and a steel plate atop each. Sometime I'll do something different, maybe even add another layer. Its easier on the back with it even a foot taller.
    Its not too much of a chore to raise and lower the f500, worst of it probably shortening the stove pipe with a cut-off wheel.
    Sca
  20. Old Nate
    Old Nate
    Western PA
    I think I’m going to go 12” off the ground. My current stove is about 7”. I think the extra 5” will feel pretty tall.
    This is what I’ve been leaning towards. I don’t know, we’ll see…
    Stephiedoll, WESF and Sirchopsalot like this.
