Dead and Down
Discussion in 'The Wood Pile' started by jo191145, Jul 6, 2022.
  1. jo191145
    I can do that.
    2991FD5B-AFF1-4B57-BA37-0061621D245A.jpeg E6D18A6B-CCE3-4C53-8CC9-4ABC3A527FE2.jpeg EF3448DB-BCE4-429F-8981-5DCAAACA0750.jpeg
  2. JPDavis
    JPDavis
    Prescott, AZ
    If you go even or a little below on your back cut the fibers will tend to be ripped out from what is felled as yours did. If you go above the bottom of the notch with the back cut your fibers will tend to be in the stump. If the tree is alive or dead and the variety of tree also play into it as well. I'd like to get input on this question from an actual logger. I've fallen hundreds of trees but mainly conifers and the oak in your pic is far taller than any in my area.
    amateur cutter, jo191145 and Chvymn99 like this.
  3. Canadian border VT
    IME the trees hit by lightning are usually dry. So put a moisture meter to splits. Dry oak is a gooder thing!
    amateur cutter and jo191145 like this.
  4. jo191145
    Hard to tell from the pic. My back cut ended one inch above the notch. I was aiming for two LOL
    amateur cutter likes this.
  5. jo191145
    Didn’t bother with a MM. The top branches were stove ready. Lots of punk tho. Much of it went in the fire pit. I’m beyond the days of saving every scrap. Some got split today and went in the general mixed hardwood pen.
