anyone ever use Mechanic in a bottle in a 2 stroke motor??
Discussion in 'Chainsaws and Power Equipment' started by B.Brown, Jun 19, 2022.
  1. B.Brown
    B.Brown
    USA
    that is the question? let me know if you have, it takes 1 ounce per gallon of gas, plus the 2 stroke mix as well. Supposed to revitalize the rubber parts in the carb, as well as plastic parts. Say's to run it for 5 min, then let it set for 8 hrs. Anyone tried it? I"m about to.
    metalcuttr and M2theB like this.
  2. Andyshine77
    Andyshine77
    Cincinnati, OH
    No, and I see no point in it, unless maybe carb rebuild kit is no longer available, which is unlikely. It's basically snake oil, and at absolute best, a temporary solution. Carb rebuild kits and fuel lines are inexpensive, and will fix the problem long term.
  3. MasterMech
    Nothing to lose other than a couple dollars. (as precious as those are these days...)
    It might fix the problem. Or you might end up purchasing a carb/kit anyways.
    B.Brown, Ohio and SKEETER McCLUSKEY like this.
  4. Yawner
    Yawner
    Louisiana
    I think I tried it a couple of times on dead saws and it hasn't worked. If it did, I don't remember it. I do remember the last time, it didn't work! I can see how it is possible that it might work.
    Andyshine77 likes this.
