Moisture Meter Newbie
Discussion in 'The Wood Pile' started by M2theB, Jun 19, 2022.
  1. M2theB
    M2theB
    Central Massachusetts
    My youngest got me a meter for Fathers Day. Very cool and sweet.
    I grabbed a piece from what will be first in the 23/24 season, oak below. And looks like a blowdown harvest.
    Then grabbed a piece from the upcoming 22/23 season, maple below.
    Both are measures from fresh split faces. I think the numbers are good.
    My question is when should I take the reading. I’m inclined to say almost immediately.
    And the reason I ask is that the longer in held the meter in the wood, the lower the number got.
    Or should I hold it and expect it to find a final value?
    Elvisss222, SimonHS, JDU and 14 others like this.
  2. The Wood Wolverine
    I take it right away.
  3. brenndatomu
    Nice!
    Take it right away...and the wood should be somewhat close to room temp.
  4. Ctwoodtick
    Ctwoodtick
    Southeast ct
    I try to push the pins in as far as I reasonably can.
  5. buZZsaw BRAD
    Handy gadget for a burner/hoarder. I check right away. Be careful of the point as real hard wood will bend them. Ask me how i know this and yes it was dead BL.
  6. Juniper Hill
    Juniper Hill
    Washington state
    My moisture meter has a pad mode. I find it to be more reliable than the pins.
  7. Erik B
    Erik B
    Western Wisconsin
    M2theB If wood is to be below 20%, which range do you use with that meter to determine it is dry enough to burn?
  8. jo191145
    Use the percentage. If I’m reading your question correctly that MM is geared towards construction and lumber. The lights are just quick reference guides not separate modes.
  9. LordOfTheFlies
    LordOfTheFlies
    NY
    You should use the highest percentage possible. So yeah, earlier the better. So if it reads 21% at first but then it goes to 17%.......I would use the 21%. I.e. be conservative, not optimistic.
    And those splits look old. You split the split in half and measured the inside yah? How long has that been seasoning? Must be a while.
  10. LordOfTheFlies
    LordOfTheFlies
    NY
    I have the exact same meter. Be careful on the initial press. You can bend those pins easily. And then you have to replace them. Ask me how I know this. And ask me where my replacement pins are and I'll tell you I have no friggin idea.
  11. JiminyKicket
    JiminyKicket
    Seattle
    Exactly all of this. I’ll add that I just bought another set of replacement pins and I already don’t know where they are.
  12. T.Jeff Veal
    Nice gift. It works well.
    It has 2 modes, 1 for construction lumber, 1 for firewood.
    We have the same meter.
  13. Eckie
    Eckie
    I have the same meter, at least one pin has a slight bent tip, I still shove it in the wood. Not sure what mode I've been operating it in though now that T.Jeff Veal says it has 2.....
  14. LordOfTheFlies
    LordOfTheFlies
    NY
    LMFAO. Yes sir. Great minds think alike.....and I can't find **** either. :p
    M2theB, T.Jeff Veal and Eckie like this.
  15. jo191145
    I stand corrected. Serves me right for assuming they were “dummy lights” LOL
    M2theB, buZZsaw BRAD and T.Jeff Veal like this.
  16. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    :BrianK: Get on the 3 year plan and don't worry about a meter. I've always said: "The best device for measuring the moisture content of firewood is a multi-year calendar."
  17. buZZsaw BRAD
    you know what they say about assume? :whistle:
  18. The Wood Wolverine
    a s s .. u .. me :salute:
  19. jo191145
    There’s a valid reason I used that specific word. ;) :)
  20. buZZsaw BRAD
    OH! and i assumed you sere serious! :rofl: :lol:
