13 Hours?
Discussion in 'Modern EPA Stoves and Fireplaces' started by mattjm1017, Oct 26, 2013.
  1. mattjm1017
    mattjm1017
    I lit the stove this morning at about 7am we left for the day didnt get back until about 8pm the stove was still at around 150* on top the house was warm and there was enough little glowing coals in the stove to do a reload and get things rolling again:fire::cool: Does that count as a 13 hour burn or what?
    Gark, charlie, clemsonfor and 3 others like this.
  2. Certified106
    Certified106
    In The Hills
    Sure if the house was warm and you could restart the stove with no matches sounds good to me. Congrats
    clemsonfor and mattjm1017 like this.
  3. mattjm1017
    mattjm1017
    I dont think I had much time left there wasnt much in there to go on and it warmed up this afternoon so Im sure that helped out but I restarted it without a match. Im sure in the dead of winter I might not be able to pull this off but if I can keep it up through the rest of shoulder season that would be great.
  4. Backwoods Savage
    What matters is how it worked out for you. Sounds as if it did just fine.
  5. mattjm1017
    mattjm1017
    Thanks Dennis I guess the biggest reason I started this thread was because I am always reading about people getting 10+hour burn times (with of course the exception of Blaze King owners I understand that with the powers of aliens they can get at least 72+ hour burns off of some kindling) and Im curious as to what exactly that means especially since last year I was struggling with getting anything to burn.
  6. Pallet Pete
    Pallet Pete Moderator
    Ovid
    Matt you are doing just fine. The difference may be in the wood itself or how dry it is. Most likely that its dryer than previous years.
  7. Backwoods Savage
    Like Pete states, the wood makes a lot of the difference. But then, we could say we get 12 hour burns and more even off of 3 splits. That is because this time of year we typically put in 3 in the morning and 3 at night. That keeps the house plenty warm and sometimes too warm. But I would not consider doing that in mid-January.
    mattjm1017 and Pallet Pete like this.
  8. mattjm1017
    mattjm1017
    The wood definitely makes a huge difference. I have to ask though how big are your splits? I cant get away with just 3 but mine are pretty small I split everything around 2-4" in order for it to season faster the stuff Im splitting now is bigger as I have more time for it to season. Im guessing that yall are going with bigger splits.
  9. Trilifter7
    Trilifter7
    Waynesville, OH
    Sounds like a good burn to me! I vary my splits from 3" up to a few 8" pieces. I just started my stash last season so anything bigger than 5-6" I keep for more than a year out.
    mattjm1017 likes this.
  10. Mitch Newton
    Mitch Newton
    Beavercreek, Ohio
    If the wood is well seasoned, the big splits start as easy as the small ones. Sounds like your stove is doing what it's supposed to do.:fire:
    mattjm1017 and Trilifter7 like this.
  11. USMC80
    USMC80
    Definitely counts. House is warm and still have a bed of coals
    Mitch Newton likes this.
  12. Backwoods Savage
    If you look on the left hand side. Near the bottom you will see a piece that is nearly square. I just measured that and it is 3 1/2" x 4". We don't have many that are any larger than that.
    Maina, clemsonfor and mattjm1017 like this.
  13. clemsonfor
    If were counting a warm house and coals still there to just restart a fire and 150-200f stove.....if that's the case I can get 24-36 hours on a full load!
  14. Steve
    Steve
    Stouffville, ON
    Yes but August burns don't count :p
    Trilifter7 and mattjm1017 like this.
  15. clemsonfor
    Talking November in SC. But I do have a 3.5 cuft catalytic stove.
  16. Oldhippie
    Oldhippie
    Ashby Ma
    It never fails to amaze me how long coal embers can last.. a great source of house fires here in the Winchentucky area of Massachusetts when people clean their stoves and do not properly dispose/store the still hot ash and coals.
    Add some air, and some new fuel and open the draft, and wait 5 minutes and you you get flames more often than not even when you can easily put your hand on the top of the stove. Those chunks just need some air.
  17. mattjm1017
    mattjm1017
    Thats the truth and sadly a lot of people learn that lesson the hard way.
