Splitter isn't cooperating
Discussion in 'Chainsaws and Power Equipment' started by WinonaRail, Jun 9, 2022.
  1. WinonaRail
    WinonaRail
    Indiana, US
    Full disclosure - I'm not a mechanic. I started the Black Diamond to finish off some dry ash. It started on the first pull. I shut the choke off and throttled up. Then as I was reaching for a round, it died. Pulled a few times and nothing. Checked fuel. There was plenty. I pulled it into the barn.
    I topped the oil and hydraulic fluid off, blew out the air filter and cleaned the spark plug. It probably needs to be replaced. I tried every combination of choke position, fuel on/off and throttle. It never fired. What do the experts say?
    Sent from my QTAXIA1 using Tapatalk
  2. Wolley
    Wolley
    My lawn mower was doing the same last week. I drained the carb bowl then it was good to go after. Must have been some junk or water in there.
  3. Canadian border VT
    Motors need 3 things to run air fuel spark.
    My guess if it started and died.. is fuel
  4. WinonaRail
    WinonaRail
    Indiana, US
    Tonight the fuel will be drained and fresh added. Wish me luck!
  5. Canadian border VT
    Then hit carb with some carb cleaner
    metalcuttr and WinonaRail like this.
  6. WinonaRail
    WinonaRail
    Indiana, US
    Can do. Thanks!
    metalcuttr and brenndatomu like this.
  7. LordOfTheFlies
    LordOfTheFlies
    NY
    Check if you have a low oil sensor. Sometimes they go and you can just short the wire and bypass it if you are the type of person to be on top of making sure you have enough oil.
  8. WinonaRail
    WinonaRail
    Indiana, US
    I'm guessing I do because I know it won't start/run with low oil. Thanks!
  9. brenndatomu
    This ^ ^ ^
    My guess is the carb was not drained of fuel during storage, and the float/needle is stuck in the closed position...so it ran on the fuel that was in the bowl and then died. You might get away with just tapping the side of the carb bowl with a screwdriver handle to get things loosened up...or you might need to take the bowl off and clean things up...on many splitters the carb bowl can be removed without taking much of anything else apart...sometimes just one main bolt in the center of the bottom of the carb bowl.
  10. buzz-saw
    buzz-saw
    Ct.
    My guess it is fuel related ; most likely lack of.
    You did mention it did fire so at least at that time you had spark.
    What motor is it?
  11. Canadian border VT
    Yes I agree with brenndatomu .. Mostly cause he smarter than me!!
  12. brenndatomu
    Hey now, I might have more experience with the mechanicals, but you can run circles around me when it comes to the financials! ;) :rofl: :lol: :handshake:
  13. Canadian border VT
    Me run. :rofl: :lol::rofl: :lol: 5 miles you would need a calendar not a watch :faint:
  14. WinonaRail
    WinonaRail
    Indiana, US
    So here's the update...I pumped fuel out of the tank and then drained fuel from the bowl. After using copious amounts of carb cleaner, I added fresh fuel and a fuel additive. Pulled the cord. No bueno. Rinse and repeat with same results. Made a trip to Mendards the next day and grabbed a spark plug. Changed out and started on the second pull. I ran it for almost 2 hours yesterday with no issues. Life is good again.
    metalcuttr, MAF143, JD Guy and 6 others like this.
  15. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Glad you got it running, stinks when equipment doesn't cooperate when we need it.
    metalcuttr, WinonaRail and walt like this.
  16. isaaccarlson
    isaaccarlson
    Colfax, WI
    I always check for spark first. I have had a wet air filter keep an engine from starting. Carb problems are common after storage.
  17. B.Brown
    B.Brown
    USA
    we had a similar situation with a power washer, could not get it started, mechanic showed up, said the plug was “fuel fouled” changed out the spark plug NO MORE PROBLEMS! Glad you got it running! Happy day/splitting!
  18. WinonaRail
    WinonaRail
    Indiana, US
    Isn't that the truth! I hate looking at piles of rounds, thinking about getting even more wood and then realizing I can't split what I have without my splitter.
  19. WinonaRail
    WinonaRail
    Indiana, US
    It's always the little things. I'm going to try to get through about a cord this weekend. Then I'll be able to relax...not!
  20. WinonaRail
    WinonaRail
    Indiana, US
    I knew storage wasn't the problem (I split all year so the splitter never sits more than 2 weeks at most). However, I got caught in the rain one night and didn't get a chance to cover it. I figured with the driving rain, it might have gotten water in somewhere. At least it was a simple fix. Less than $2 at my local Menards. And I took the time to go through everything while I was at it so I should be good for the rest of the year.
