Fix it fuel?
Discussion in 'Everything Else (off topic)' started by Greenstick, Jun 7, 2022.
  1. Greenstick
    Greenstick
    Anyone use fix it fuel ever? Was talking with a guy and he said that if he ever starts to notice a 2 cycle start to get tougher to start or run, he dumps the gas out and runs a tank of this stuff. Runs it for 2 minutes to get through the system then let's it set a couple days then burns the tank out and claims to have good luck. I saw a quart was around $13 but if it does work it would be worth it. What is your experience with it?
  2. stuckinthemuck
    stuckinthemuck
    Stabil has a product that I used in my snowblower last winter. Worked great.. ran it through a couple other engines as a preventative measure. Perhaps this has a similar formula. Do you have a link to the product you are referring to?
  3. TurboDiesel
    Seafoam seems to do the same.
    huskihl
  4. huskihl
    huskihl
    Did you ever figure out what it was that gelled in your generator? I know you were thinking it was the sea foam that caused it, and it very well could have been. Just wondering why. I’ve never seen it do what it did to yours. But it definitely cleans things up inside a carburetor
  5. brenndatomu
    My buddy used SF in his sled religiously...some of the nastiest carbs I've ever been in...and it ran fine the previous season.
  6. yooperdave
    I have been shutting off the gas tank and running the engine out of gas as of last few years.
    So far, so good.
  7. huskihl
    huskihl
    Tim found the fuel gelled and his camper generator and we were all figuring it was caused by the sea foam. But obviously, it would have to have been mixed with something else because seafoam doesn’t just turn into a gel.
  8. brenndatomu
    Just what I found...a skunky gel
  9. huskihl
    huskihl
    I believe that is from excess water, but I have no proof. If there’s no water to speak of, it seems to leave everything spotless inside carburetors
  10. brenndatomu
    That's better than nothing... but still leaves a small puddle of goo in the carb after a while
  11. yooperdave
    Back to using stabil then I guess. :sherlock:
  12. Greenstick
    Greenstick
    I'm technologically deficient and don't know how to do the links things. Here are a couple shots of what he was talking about. Screenshot_20220608-223315_Samsung Internet~2.jpg Screenshot_20220608-223357_Samsung Internet~2.jpg
  13. Barcroftb
    Barcroftb
    The Mitten
    Give Startron a try. It’s mo better gooder:yes:
  14. brenndatomu
    X2
    Barcroftb, TurboDiesel and Screwloose like this.
  15. Screwloose
    I've been using stabil since it first came out and have not had any problems. What does startron do that's better?
  16. TurboDiesel
    It definitely cleared out a bunch of goo from somewhere. The guy that worked on it didn't know where it came from... the cleaning helped some, but then he rebuilt the carb and its been running good ever since. I think it's been 4 years.
    We run it every month and put a load on it for 20 minutes (with a small electric heater or the a/c)
  17. Barcroftb
    Barcroftb
    The Mitten
    Star Tron Enzyme Fuel Treatment Gas Additive Small Engine
    Essentially rather than a petroleum distillate based formula it relies on a enzymatic formula to stabilize fuel and remove water. In addition, unlike stabil, it will rejuvenate old fuel. I also think it performs better in preventing deposits, gum, crud, etc. though I have no scientific proof beyond just anecdotal.
  18. ammoaddict
    ammoaddict
    Granite Falls, NC
    I put an ounce of seafoam in every gallon of 2 cycle fuel I mix up. I've never had any problems with it.
