Solo 134 brush cutter/weed wacker
Discussion in 'Chainsaws and Power Equipment' started by Cold Trigger Finger, Jun 5, 2022.
  1. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    So my Solo quit working the other day. I was goin right aheadoner and hit an old rope that someone left lying and the brush grew up through.
    Then the engine would wind up but the blade wouldn't turn.
    Any ideas ?
    Screwloose and M2theB like this.
  2. Chud
    Chud
    Threads wrapped up in cutter head.
  3. Ohio
    Not Ohio
    The blade head could have loosened up and walked off the drive shaft. That has happened before on my stihl fs110.
  4. Screwloose
    If the engine revs up freely you could have snapped the drive shaft/cable.
    Cold Trigger Finger and Warner like this.
  5. buzz-saw
    buzz-saw
    Ct.
    This.
    I didn't think you were supposed to run a blade on a trimmer that has a cable drive , only on driveshaft models.
    I could be wrong? Hey there is a first time for everything.
  6. Screwloose
    I've seen cables on blade capable units. I think you may be thinking about curved vs straight shaft types.
  7. buzz-saw
    buzz-saw
    Ct.
    I know that curved has a cable.
    Not sure on straight shaft though.
    Thanks for learnin'me on that. Never gave it much thought.
  8. Cold Trigger Finger
    Cold Trigger Finger
    It is a straight shaft. I need to year into it gently. Thank you for all the replies. I very seldom get enough bars to get on the site.
    I'm hoping I will have 1 more day and will be done siding my entryway. Then I will get on it.
    Chud likes this.
