Stihl MS460 Rebuild?
Discussion in 'Chainsaws and Power Equipment' started by LordOfTheFlies, Apr 16, 2022.
  1. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    Definitions of Southeast Alaska Timber beast dialect.
    Tramp = Verb - to guit, go down the road , usually involves a float plane to get to town.
    Tramp = noun - a logger or Fallers that is a tramp , doesn't stay long in 1 camp.
    Sometimes because the pancakes in ( the Cookhouse = galley and mess deck or kitchen and cafeteria , chow hall ect. ) Weren't round enough ! Could NOT go in the cookhouse with work clothes on ! Or a hat !!
    Cliff, = a shear rock face or bluff.
    Bull Buck = boss of the cutting crew. ( In a perfect world , the most experienced Faller.
    Nice guy, always stuck up for the fallers.
    Sadly , the world ain't perfect !)
    Bushel = 1,000 board feet Scribner scale.
    Small end diameter of the log. With fast tapering red cedar a guy did a lot of cutting for a little scale :#(
    Cull scale = all the stuff a faller has to cut that is not merch timber. Ie , snags, riggin cuts ( made so the riggin crew can get the logs out or get them out easier.)
    Root cuts, school marms = forked tops, break cuts. All these went on cull scale which was the diameter of the cut at a certain length. Example , if the company paid 24 ' for snags and 12 or 16' on root cuts , riggin cuts , break cuts, buck outs and school marms then it was the diameter at those lengths Scribner scale.
    One outfit I cut for paid 40 ' on the snags and 24' on the bucking cuts including root cuts. But, they paid less than half price for cull scale.
    Crew boat= when the crew has to get to work and back to camp via water . Most of the time a crew boat was used. Very common with float camps and when starting a new sale.
    Finger benches. = Usually skinny ledges that timber grew on between the cliff faces . Sometimes a 10' wide finger bench would have stooled up , 8'diameter at the butt of the tree timber on it. So spring boards had to be used. Sometimes it would be 75' or more to whatever was below . Falling off a spring board or having it come out of the tree was Never a good thing !
    Counting limbs = Some places only sold export round logs. There were Many different sorts for different lengths , diameters and grades of logs. One thing that changes the grade is the # of limbs on a log or where the limbs were on the log. So we would have to count limbs to try to get logs in a higher grade.
    We did NOT get paid any more for doing it and it slowed us down and there by cost us money.
    On the Ground and On the Hat = No fooling around to enjoy the view or experience of being a great and mighty slaughterer of an ancient boreal forest. You could do that after work. None of this dinkin around on the stump blipping the throttle when falling . Wide open , dogged in and eating wood . Tearin em off the stump . Flyin down the tree limbing and buckin and measuring and writing the scale on your tin hat then on to the next and the next ect ECT for 6 + hours . As Wide open as your brain and body could go. When everything went right. It would make a guy good money. But it Never made a a guy any nicer or more pleasant to be around. Bushlers tended to be over the top impatient. Mean , cranky , hard to get along with men that were brutally strong and very quick on their feet and usually much quicker tempered. Since Everything they did to make a living was hard to almost impossible. They kinda had to be. They were also total adrenaline junkies.
    brenndatomu likes this.
