Pressure Washer Recommendations
Discussion in 'Chainsaws and Power Equipment' started by buZZsaw BRAD, May 24, 2022.
  1. buZZsaw BRAD
    In the market for a decent pressure washer. Considering Stihl from OPE dealer. Dont need pro quality, but reliable unit for occasional use maybe six times year. Home use and and sometimes for work. I thought of going electric but gas seems to be more ideal for my needs. Price important too.
    Any Stihl owners? Big box brand okay? Thoughts/input FHC? Thanks in advance.
    Haftacut, Chaz, metalcuttr and 2 others like this.
  2. Brian72
    Brian72
    PA
    I'm very happy with my Simpson. I believe I have the 3300 psi model. Don't know anything about the Stihl unit.
    Sent from my moto g power (2022) using Tapatalk
  3. jtstromsburg
    jtstromsburg
    Stromsburg, Nebraska
    Got a generac at work and it’s been good for weekly use for three + years. Starts east too. I have an older Troy built at home and have out tons of hours on it. Did have to change the pump out two years back, but it was $60 on Amazon and a quick easy fix. if I was buying now, like most small engines, I’d look for Honda engine and easily serviced pump probably.
  4. buzz-saw
    buzz-saw
    Ct.
    It is all about the pump. That is the heart of the unit.
    The rest of the unit doesn't do much except hold it all together. May have a soap bottle and a couple other bells and whistles but it doesn't mean much as far as the actual washing.
    Are your saws that dirty they need a PSI washer?
  5. buzz-saw
    buzz-saw
    Ct.
    Just to add to my last post. Sure some have better motors than others as well.
    Maybe a Honda on some and others might have a China clone. This will obviously relate to the price as well.
    Not a fan of the imported stuff but for something that is not going to be used daily the clones are not a bad way to go.
    Yeah I know , I said it............. Not a fan of them but hard to beat for something that gets used only on occasion.
  6. Sawdust Man
    Sawdust Man
    I've have a 3000 psi Ridgid branded unit, it's got a Subaru engine and a cat pump, we've used it a whole lot washing logs for the mill with zero problems so far, it's probably got 200 - 300 hours on it now.
    Chaz, JD Guy, metalcuttr and 2 others like this.
  7. T.Jeff Veal
    We have a Craftsman from Lowe's, caught it on sale a couple yrs ago.
  8. Screwloose
    I bought a Cat with a Honda from Northern china tool around 20+ years ago and have never had any problems.
  9. Lennyzx11
    Lennyzx11
    Bennington Vermont USA
    I also have a simpson with a honda motor also. It's a beast.
    Being on well water I have to baby it it bit as it can pump more GPM than what my well pump can provide. It will peel paint if not careful.
    I picked up a ryobi electric on the clearance rack that has been very good to my surprise for cleaning mowers, tractors siding, etc.
    Haftacut, Chaz, metalcuttr and 3 others like this.
  10. JRHAWK9
    JRHAWK9
    Wisconsin
  11. Ward Hoarder
    Ward Hoarder
    West Virginia
    Ridgid with a Kohler motor. It has served me well.
  12. Czed
    Czed
    Wv
    Simpson 3400 3 years does excellent
    My contractor friends all run Simpson
    And Honda.
  13. T.Jeff Veal
    Lowe's has a nice Simpson on sale till tomorrow... Screenshot_20220524-162837.png
  14. Screwloose
    Chaz, metalcuttr and T.Jeff Veal like this.
  15. buZZsaw BRAD
    LOL!!! Saws not that dirty, but decks, steps needs washing and i picked up a job where ill need one washing a patio and steps.
  16. Captain Kirk
    Captain Kirk
    Northern New Brunswick
    The biggest thing you want to look at is the GPM and PSI of the pump, to compare different machines multiply those 2 numbers together to figure out a punch factor. Example 1.3 gpm @ 3000 psi has less punch than 2 gpm @ 2500 psi. More gpm the better the result. I used to be a certified Hotsy technician.
  17. Captain Kirk
    Captain Kirk
    This would be a good unit. Most of the cheap China pumps are rated for around 250 hours of service time.
    And that one looks like it has a cat pump on it.
    Chaz, metalcuttr, T.Jeff Veal and 2 others like this.
  18. buZZsaw BRAD
    Can i expect to get much for $300-400? Again not trying to take paint off a car, just crud and dirt off exterior surfaces.
  19. Captain Kirk
    Captain Kirk
    Probably could pick us a cheap karcher electric for around that, won't have much for hose but they will do the basic for you
  20. jtstromsburg
    jtstromsburg
    I believe this is what I have at work. It cleans vehicles at school more than once a week and the Ag Class uses it to clean equip and their shop space fairly often also. We originally bought it to clean bird crap from concrete and it ran the normal tips, including turbo nozzles and I’ve also ran a twin nozzle concrete cleaner (the disc looking deal).
    11% off at Menards via rebate.
    Generac® 2900 PSI 2.4 GPM Gas Pressure Washer at Menards
    https://www.menards.com/main/p-1538720893379.htm
