Never considered where to put year 4 stacks... Input please
Discussion in 'The Wood Pile' started by cnice_37, Aug 21, 2014.
  1. Backwoods Savage
    You are looking good on the wood stacks and can be proud of the work you've done. Now you just need a little tweaking here and there and you'll be all set. You have some of it top covered so now get the rest of it top covered. I have a feeling this fall will be wet and particularly so in your area so get it top covered as soon as you can. And don't worry, it won't rot.
    First order of business is to forget the idea that wood has to have sunshine. It don't. Especially when you are more than a couple years ahead or even more than a year ahead. In the past at times we've found ourselves in a bad position with not enough wood and I recall 2 different years in particular. One year all we could get was popple and most of that was dead. We cut it during the winter and spring and by fall it was dry. It was never stacked in the sunshine but was stacked near some rows of pine trees. It didn't even get much wind. It burned just fine. Another year we did the same but that time was mostly all soft maple. For sure it was much better than the popple and it even kept the fires longer. It was a blessing for sure. Once again, that maple did not see sunshine. But, the stuff was top covered in the fall then we just took from the stacks as we needed. We would stack enough on the porch for about a week's worth of burning.
    When you are looking at 3 years worth of wood, sunshine is something that is nice but not necessary. Shoot, you don't even need much wind once you are that far ahead but we still aim for that if possible. I highly suggest you start stacking more rows together. Put 3 rows together or even more. You can do like this if need be:
    Don't worry, it will be nice and dry when you go to use it, even if you left it 10 years like that, it would be just fine. Oh, and on that last picture, yes I did fix the top covering. Notice the one sheet of galvanized didn't have any weight yet in that one corner. It does now.
  2. Backwoods Savage
    Do the holzhausens if you like but realize that it is a lot more work (in my case, at least double the amount of work) to build one and there is no benefit unless you just like the looks of it. They will also actually take up much more space so if space is at a premium, I advise you stay away from them.
    Shawn Curry likes this.
  3. Backwoods Savage
    No doubt about it Scotty. You have me beat as I don't think we've ever had that much on hand. Congratulations! It's worth at least 3 atta boys!
    Scotty Overkill likes this.
  4. Backwoods Savage
    Some lean in the stacks is quite normal. However, if you could stop the ground from freezing and thawing it might help. If they start leaning a little, push them back. I'll never forget, I think it was last summer when Fire Chief Steve paid is a visit and as we were taking a little walk, he spotted the stacks in the pictures below. Wow!!!!! He actually ran over to take pictures as he could not imagine any of our wood piles looking that bad. It was really funny, so here is what they looked like.
    What the story is here is this was an experiment. It had been many, many years since I had left wood stacked but not covered and one year I thought why not do it again for kicks. After all, at the time there were many on the forum preaching that wood need not be covered. So, that one year we did not cut a lot of wood and I decided it would not be covered. Oh what a mess it turned out to be!!!
    Long story short, I will say the wood was terrible compared with what we are accustomed to burning. The wood there was red oak, pin oak and ash. There may have been a couple cherry or elm in there to but I don't remember. I ended up covering one stack and that will be burned this coming fall but it will be a long, long, long time before we leave wood uncovered all year long. It just is not as good for burning and the stack really deteriorate quickly.
    Stinny, Loon and Scotty Overkill like this.
  5. Backwoods Savage
    Very true.
  6. Shawn Curry
    Shawn Curry
    Western NY
    It is more of a looks thing for me. The space I'm running out of is space that's "close to the house but mostly hidden from view". I figure if I gotta look at it for three years, might as well make it look pretty.
    I do like your nice neat cubes too though. Not exactly looking forward to all the extra work; I'm already splitting by hand. I dunno got a little while to think about it.
  7. Paul bunion
    Paul bunion
    Stack it in bigger cubes like others have said. You have your wood well up off the ground so moisture from under shouldn't be a problem. Top covering as Scottie said is the other key, rain is the enemy. If you never let it get wet it will just get drier, it has no choice (that is till it reaches equilibrium). Yes, sun exposure will accelerate drying considerably, but you have time on your side so don't worry about it.
  8. Paul bunion
    Paul bunion
    I think your stacks lean due to a gravitational anomaly caused by Scottie's pile. To minimize this effect try stacking your wood only in rows that are perpendicular to PA. :)
  9. Stinny
    I'm gonna try that right there... can't be too cautious... :whistle:
  10. Loon
    Loon
    North of the border
    You are one wise dude with wood burning Sav! :yes: Thanks eh! :)
    Terry
  11. Stinny
    You know Dennis, your story here of the difference between covering firewood vs not covering made me think of a common old reality preached here in Maine (anywhere actually)... if you keep your barn roof in good shape, the rest of it with last forever. Our old farm had 2 barns, one was built in the mid 1800s. Any of the big beams, that were protected from the rain, were all fine still. Firewood, top covered and off the ground since the 1800s, should still be fine to burn today... and perty dry too... :rofl: :lol: Your decades of experience of covering firewood puts a large !!!! on it... :tree:
  12. Sinngetreu
    Sinngetreu
    North Central Iowa
    I like Holzhausens. I dont think the work is that bad, but then again, Savage has a lot more experience on me. My wife was about aesthetics and she wanted something that looked nice so I built two of them this year. The wood dries nice and they look pretty cool. One thing I like about Holzhausens is that if you do it right, you can build them 10+ feet tall. The general rule of thumb is to make sure that the footprint diameter is the same as the height when you finish stacking. 10 foot diameter will build a 10 foot high stack. This isn't set in stone, you can go higher, but I feel like the base is better if its not built too much taller than the diameter. Just do yourself a favor and if you build one, dont make it under 6 feet in diameter otherwise having every split point to the center becomes much more difficult. Larger diameters are easier to fit splits in.
    Also, when you start the roof, you will want to have a inner ring instead of outer rings to make sure that the roof slabs are leaning like shingles. Also, be sure to fill the center as you build.
    Some people have stacked the center vertically but I always through my splits in randomly. I'm not sure it matters.
    Before anyone starts getting upset, I'm not pressuring anyone to build a holzhausen and if you hate them...that's fine with me!
    Shawn Curry and Firebroad like this.
  13. Firebroad
    Firebroad
    Finksburg, Maryland
    WONDERFUL video, thanks for sharing!
    Sinngetreu likes this.
  14. Sinngetreu
    Sinngetreu
    North Central Iowa
    Your right about not wanting to deconstruct it. I'm not gonna lie, its gonna be hard!
