My first splitter incident (no bodily harm)
Discussion in 'Chainsaws and Power Equipment' started by The Wood Wolverine, Apr 13, 2022.
  1. The Wood Wolverine
    So last weekend I had a large ugly crotch piece to split. It barely fit and I proceeded to push the wedge in. After some grunting, POP. Almost hit my nuggets. :picard: It bumped me hard but didn’t fly apart or anything. Then I reversed direction to get the wedge out of the mess. Cleared the wood and on the next piece, I notice this:
    I have no ideas if it happens on the push or pull or @ the pop. I’ve owned this 10 years or so and haven’t even dinged the splitting edge or filed/sharpened it yet.
    So my question is… how to fix. I’m thinking lots of heat to bend it back so it doesn’t crack when cold. Thoughts are appreciated.
  2. jmb6420
    jmb6420
    Grand lake, Oklahoma
    I'd remove the cylinder to protect the seals. Get a rosebud and do exactly as you described. Have a bfh and some big wrenches to massage it back to original.
    Mike in Okla
  3. The Wood Wolverine
    I did plan to remove the cylinder when it comes time. Are we talking red hot or near red hot? I have 2 big pipe wrenches and a piece of pipe that goes over the handle for leverage.
  4. jmb6420
    jmb6420
    Whatever it takes to get it to move. As little as possible but as much as needed.
    Mike in Okla
  5. The Wood Wolverine
    Thanks for the advice Mike. :handshake:
  6. jmb6420
    jmb6420
    Pics when done!
    Mike in Okla
  7. Ohio dave
    Ohio dave
    Akron, OH
    No, want video of it being repaired
  8. Casper
    Casper
    If you buy a rosebud on FBMP or CL be aware, there is an acetylene version and a propane version. I think the propane tip is recessed? Definitely worth calling a welding shop to verify the difference. Screenshot_20220413-144455_Chrome.jpg
  9. The Wood Wolverine
    Thanks for that Casper.
  10. Canadian border VT
    Wish I could offer advice.. I don’t know how to weld. I didn’t have the electricity to weld for years. And one of the best welders in the state was a mile down the road from me and his daughter is across the street.
    I am a believer in BFH :eek:
  11. The Wood Wolverine
    If I need a weld, my son is very good at it. He recently passed certs at a new place and in a week will be making much more than I ever have.
    7200C047-E4D9-4653-81A6-E3CF1C2EC593.jpeg 792C8B2F-EBBD-42A5-A755-D6645E36C837.jpeg
    His old job was welding dump truck suspension parts:
    2EE2BEB1-F7BF-498F-8CC4-591606EA0177.jpeg 47D97F4A-FA82-4FB4-A40E-19EF16DB61B4.jpeg
    Bert, T.Jeff Veal, Horkn and 14 others like this.
  12. Canadian border VT
    I like it!! Your kid can be what’s the word
    Volun-told
    Bert, T.Jeff Veal, Horkn and 8 others like this.
  13. The Wood Wolverine
    Lol! Hopefully nothing needs welded. He does not have a welder but I have access to one if needed.
    Bert, T.Jeff Veal, Horkn and 7 others like this.
  14. Ford
    Ford
    SW MI
    FAF2A8CF-A118-45C3-99D0-CA979D7236CC.jpeg Just got done fixing a splitter that had a similar design and that whole side rail that was welded to the I-beam broke off. It’s not super sturdy and the factory welds were poor and only in limited spots on the inside. After getting it straight it might be wise to weld it up properly. Mine is a county line 40 ton
  15. LinkedXJ
    LinkedXJ
    My black diamond 30 ton is tweaked like that, not quite as bad though.
    Thats how i bought it though.. on clearance..
    A pallet rack failed above it and a riding mower fell on it. Lol
    Bert, T.Jeff Veal, Horkn and 6 others like this.
  16. brenndatomu
    My Champion did something pretty similar...I was able to use the ram to bend it back by wrapping a chain around both strippers and the wedge, with a piece of angle iron over the cutting edge of the wedge to protect it from the chain...then advance the wedge forward to bend it back in place.
    There is a fine line between pulling the stripper back "in" (straight up) and starting to pull it forward with the wedge...take it easy, you'll be able to tell when its time to stop (I would run the engine a tick over idle so things happen slower, and you have less "destructive" power)
    IIRC I think I put a block(s) in between the stripper on the other side (the straight one) and the wedge (or ram) to keep it from being pulled inward. This might all sound like a disaster waiting to happen, but it really is pretty quick and simple.
    Bert, T.Jeff Veal, Horkn and 10 others like this.
  17. jo191145
    Similar but not quite. My entire side rail let go. As you can see in the pic the robotic weld was only holding in the last inch or so. Possibly it failed at another point in time and I never noticed. Was easy to put some bar clamps on there, pull it back and weld it full length.
    You’ll need to determine if the weld cracked or bent.
  18. buZZsaw BRAD
    No idea on how to fix and have have had a few pops come close to the family jewels. When it "strains' to split, ill stand sideways as i can deal with a bruise on my thigh better than one "elsewhere". :emb: :picard:
    After my finger injury im giving second thoughts to sending gnarlies thought the hydro vs. noodling. Although i do enjoy watching and listening to it shear through some tough grain. Hope you get it fixed.
  19. Horkn
    That's one of my favorite words.
  20. Canadian border VT
    My daughter has exact opposite opinion ;)
