Mounting a vertical, horz splitter on FEL forks
Discussion in 'Everything Else (off topic)' started by Casper, Apr 10, 2022.
  1. Casper
    Casper
    The village has a sea of 30"+ logs in their lay down yard. I've cut there for years and yes, there is some smaller stuff, but I usually leave that for other folks who cut there, since most don't have equipment to process bigger wood.
    I have used the horizontal/ vertical splitter in the vertical position using the forks to position the round. That works OK, but requires getting on and off a lot if I'm by myself. The other option is log tongs or forks lifting it onto the push-through splitter. It has the draw back of having a 200#+ chunk to deal with until it can be broken down too.
    Here's another hair-brained idea, part way into execution. Rigging up a fork mounted cylinder and beam from the vert/horz splitter. Everything can be put back to OEM configuration except the four clearance holes for 5/8" bolts holding the fork bracket.
    The thought of mounting to the forks is two fold. I can fairly quickly back off the grub screws (5/8" bolts, nuts to be welded in pic above) and quick disconnects in the event I only have the little John Deere 870 at the site. The other reason is that I am mounting it off-set to the left so I can easily see the log that will be broken down and, in most cases, finished on the other splitter shown in the first pic.
    I don't have third function on any of my tractors so the plan is to position the splitter in the desired orientation, dis-connect the quick disconnects on normal curl/dump lines, and run hoses to the front, one with female and one male. I'll mark the tractor side lines once I make sure the cylinder actuation is the way I want.
    Will it be a bit slower than when mounted on the tractor using it's internal pump? No doubt. Will it be faster than a one legged guy, getting on and off a tractor to split using the forks as a pivoting platform, with the splitter in vertical mode? Highly likely.
    Hopefully, we test this concept after church today. Wish me luck.
  2. brenndatomu
  3. Casper
    Casper
    Looks like it's clearing up over this way...hopefully it will be nice this afternoon.
  4. Creekin
    Creekin
    Manitoba
    Good luck, hope it works out for you!
  5. Horkn
  6. Chvymn99
    :popcorn::popcorn::popcorn:
    Casper and Horkn like this.
  7. Casper
    Casper
    I had to fart with the controls on the Johnn Deere 870. I was hoping to use the dump/curl circuit but I was getting wonky pressure spikes. The extend cycle was the worst. I ended up using the loader, raise/ lower circuit for splitting and the dump/ curl to raise and lower. That worked ok, but boy is there a learning curve. Not intuitive at all.
    The concept works great. Mount is sturdy, I can move pieces around with either end of the beam. Splits fine, even without bumping up the output pressure. I would give it a solid 7 out of 10, mainly due to control inputs being the way they are. It definitely achieves the goal of making 30"+, rounds manageable.
    If anyone knows why I'm getting over pressure on a circuit with a double acting cylinder, I'm all ears.
  8. Casper
    Casper
    Here is a quick video, I have no intention of splitting this small on a regular basis..
  9. walt
    walt
    north central ohio
    I like it ,hats off to you for being creative. You probably have a fraction of the cost of a store bought unit
  10. Backwoods Savage
  11. buzz-saw
    buzz-saw
    Ct.
    Well I will give you an A+ on that one.
    Very creative and great thinking.
    Horkn, Chvymn99, Casper and 1 other person like this.
