Hang'in On Tight!
Discussion in 'The Wood Pile' started by Buzz Benton, Apr 2, 2022.
  1. Buzz Benton
    Buzz Benton
    Cottage Grove Lake, Oregon
    Here's a tight pair of pecker poles.
    They're so tied up the first one I cut didn't even settle when I cut the stump out from under it.
    It's just hanging there in mid air - it never hardly moved.
  2. gwoods71
    gwoods71
    The Mitten
    Well if that doesn't make you pucker a little....
  3. buZZsaw BRAD
    Siamese twins? Thats cool. I love "freak of nature" tree stuff. Thanks for sharing.
  4. The Wood Wolverine
  5. JPDavis
    JPDavis
    Prescott, AZ
    Codominant stems are looked upon poorly for a reason, post more pics of the outcome!
  6. amateur cutter
    I'd call them pucker poles. I hate those take downs, way to many variables, and most are bad.
  7. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Good luck and stay very safe out there.
  8. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    Face the remaining one to the lean of the cut off one. Put the backcut in carefully . The hanger will probably pull the standing tree into leade.
    I've had to do that many times pre commercial tree thinning with trees that size . And with old growth Sitka spruce and western hemlocks.
  9. MikeInMa
    If you could get something between them and using a come-along, at a distance, giving the cut one a good tug might pop it free. Emphasis on distance.
  10. Backwoods Savage
    Those are nasty jobs.
    Chvymn99 and amateur cutter like this.
