40$ Saw
Discussion in 'Chainsaws and Power Equipment' started by Slocum, Apr 1, 2022.
  1. Slocum
    Slocum
    North Central Indiana
    Bought this for a wall hanger from a coworker. 7100E966-490A-4A38-B007-8B6395410958.jpeg A0BE98DD-FD3A-4903-8044-A371D8D51408.jpeg
  2. M2theB
    M2theB
    Central Massachusetts
  3. Slocum
    Slocum
    It does actually. Guy said it ran. I need to find out fuel ratio and giv it a couple pulls
  4. brenndatomu
    :thumbs:
    Whatever you already have mixed up for your saws will work...old saws run just fine on modern oils at modern mix ratios
    M2theB, Horkn, Slocum and 1 other person like this.
  5. Chris F
    Chris F
    Micksburg, Ontario
    Nice to look at but I don't think I'd want to use one more than a couple of minutes, just to say I did.
    I would guess probably 16:1 for that vintage.
    clemsonfor, MikeInMa, Slocum and 2 others like this.
  6. Horkn
    Yep, oil was crappy back in the day.
  7. Lehman
    Lehman
    Minnesota
    I’d still consider at least 40:1 if not 32:1 even with good oil. Some of these old saws have bushings not bearings on wrist pins and crank so need more oil.
    Husky Man, M2theB and clemsonfor like this.
  8. clemsonfor
    Yea I probably wouldn't go leaner than 32:1
    M2theB likes this.
  9. brenndatomu
    I don't believe the ole Homeys are that way though...someone correct me if I'm wrong on this one.
    That was one of the reasons that these things lasted so long, all needle and ball bearings.
    M2theB and eatonpcat like this.
  10. Eckie
    Eckie
    Interesting display piece. We've come a long way....thankfully!
    M2theB and MikeInMa like this.
  11. brenndatomu
    M2theB likes this.
  12. Lehman
    Lehman
    Minnesota
    I’m sure it has crank main bearings and a lower rod bearing but quite a few had a bushing for the upper rod/ wrist pin bearings. And yes it’s just a generalization but something to keep an eye out for. Lots of the old macs had wrist pin bushings and didn’t like to be turned fast or have lack of oil in mix.
    M2theB and brenndatomu like this.
  13. Softwood
    Softwood
    Central WI
    You had to be a man to run those old saws for any amount of time I bet..
  14. Lehman
    Lehman
    Minnesota
    4A11B27E-F0C9-484B-BA82-01F8FDEBB1A3.jpeg I know these two will kick your but running them for any length of time. My 075 and 090 with 41” bars made the maple slab into a table.
    brenndatomu, MikeInMa, Chud and 2 others like this.
  15. Lehman
    Lehman
    Minnesota
  16. Rickyblazin
    Rickyblazin
    Pottstown PA
    That saw is awesome!!! We run old homelites 25:1 with tru fuel
    brenndatomu and M2theB like this.
  17. Rickyblazin
    Rickyblazin
    Pottstown PA
    I spent 40 yesterday on two homelite xl 101s myself….i got a sickness for old Homelites
    Chud, brenndatomu and M2theB like this.
