New Utility Trailer Shopping
Discussion in 'Chainsaws and Power Equipment' started by lukem, Mar 29, 2022.
  1. lukem
    I have been putting this off for years, but I think it is finally time to get a utility trailer. I have several projects lined up for this year that are going to require hauling a 30HP tractor w/FEL, lumber, steel roofing/siding, etc.
    I'm thinking 7x16 or 7x18 7K range.
    Anything I should look for / avoid when shopping?
  2. Unhdsm
    Unhdsm
    Bradford, Vermont
    If you can swing the extra money for aluminum you will get it back when you go to sell it. Aluma is a great brand.
    If you want a flat deck (not a dump trailer) I think you are really looking at "landscape trailers" and "car haulers" in those sizes.
    Wood decks are much quieter than steel and don't rust but need replacement down the road. It's easy enough to do though and they won't rust.
    Whatever you get, pick up a couple cans of fluid film at the same time and go over any steel parts on the bottom.
  3. brenndatomu
    I had an aluminum trailer, probably wouldn't buy one again...they don't rust, but do corrode...and overloading results in cracking (instead of bending, like steel) and anyplace where there is steel against aluminum will have galvanic corrosion...maybe a top of the line one would have that issue engineered out...but even a basic steel trailer is $$$ these days, let alone paying for a top end aluminum!
    Aluminum is not as easy to weld/repair once the trailer is used either. (brand new uncontaminated aluminum is the only way to get a really good weld)
  4. walt
    walt
    north central ohio
    Four or five years ago I purchased a dual axle 16' trailer to haul my Tractor on. Kinda wish I would've got the 18' ,that way I could haul another implement with the tractor.One thing I would do again is get the heavy dropgate with spring assist.
  5. Monkeysocks
    Monkeysocks
    SE Minnesota
    Get a higher weight rating then you think you need. In that size, I’d be looking at at least a 10k weight rating. The price/weight difference often isn’t a lot on trailers of the same dimensions and gives an extra 3000 lb of capacity. A 30hp tractor plus attachments adds up fast.
    Most modern half tons can tow close to if not more than 10,000 so even if your current truck can’t use the full capacity, the next one probably can.
  6. lukem
    That's kinda what I'm thinking...maybe the 10K is worth it. My current truck wouldn't tow it fully loaded but my next truck will.
  7. MasterMech
    7K is ok for a mid-frame CUT w/loader, especially if it's you doing the loading/driving. That said, I'd go to 5K axles if at all possible, even if the trailer is still rated at 7K. 16' is pretty tight for some tractors with a FEL and bucket, let alone forks or grapples and 3pt implements. 18ft or bust. If the trailer is going to get used, self-adjusting brakes are really nice, especially combined with the built in controllers on most trucks these days.
    Just this morning witnessed a Durango yanking a single axle out of HD piled high with lumber. The side rails were smiling (could see them warped inboard from behind), and the axles/tires were screaming for mercy. No brakes, and the truck was sagging hard. That guy was one pothole from a bad day for sure.
    Oh yeah - Pipe/Tube rails make a pretty stout trailer frame vs angle.
  8. Chvymn99
    I did this like year and half ago. I only have a 1/2ton truck, but went with a 14K trailer. Way overkill, but if I was spending the money i wanted a one time purchase. Beefier frame trailer, suspension, bearings, brakes and etc. For the jump from 7K to 10K to 14K was marginal when your already spending it. As far as length I'd get the longer one I think mine was 18' with 2ft dovetail with spring assisted ramps. I can now haul my JD x720 with a splitter attached with no problem.
  9. mike bayerl
    mike bayerl
    I picked up a Cam Superline Warrior 16', 10K trailer for hauling my hay, logs/lumber and my tractor, Kubota L3710. Honestly, I couldn't be happier. Price is very competitive and quality is excellent. No frills 20200318_130552.jpg 20200318_130552.jpg 94387667_676428749816985_2303206612258521088_o.jpg
  10. mike bayerl
    mike bayerl
    BTW, an 18' would be preferable to a 16' for your tractor. I got the 16' because things are real tight at my place. It works for my tractor + FEL, but if I had the room, I'd definitely have preferred the extra 2'.
  11. MasterMech
    This post dusted off a few more memories for me. :D I have personally pounded the snot outta some Cam SuperLine's. They are tough!
    Those ramps are far better than the ramps on most utility/landscape trailers, at least for compact tractors. Little rough getting a mower up 'em!
    lukem make sure the ramp will take whatever you can think of dishing out. Would you want to be able to unload the trailer with the FEL? ;)
  12. Will C
    Will C
    New York
    I have an 18' aluminum utility trailer with stowable ramps. The biggest thing I would have done differently was to buy a 10k trailer instead of a 7k trailer. 12 years ago 7k was the limit for my truck-now my new truck can handle 10k. 20' or 22' would be nice for the extra room to haul an implement, but does make the trailer a bit cumbersome. 18' is a happy medium IMHO.
  13. clemsonfor
    I have had a 7k pound dovetail car hauler for like 14 years. Almost every other time I use it I wish I had a 18 or 20footer. Get the 5k axles at least I'd say and get a longer length. My tow vehicle is about 8500 pounds max weight but that's more than the trailer. It's not weight capacity I usally need just more deck room.
    Another though. Everything is expensive so if you don't have to you might wait this out, but prices may never come down after this inflation, you never know. The good thing is your money if not invested in the market is loosening money sitting in your checking account may as well buy a tangible real item that will possibly be worth what you paid for it even a year later.
    This picture is pretty common to what I haul. And I'm always wishing I could haul an ATV or one more implement or something. Screenshot_20220331-213505-744.png
  14. TurboDiesel
    I love my H&H Speed Loader.
    10,000#
    22"
    Aluminum
    Hydraulic/electric tilt deck.
    I figured i had one chance to get it right.
    I wouldn't change a thing. (Well...except the wheels. I put aluminum wheels on it last year.)
  15. amateur cutter
    I bought a 20' 10K tilt bed trailer a few years back. For my 40 hp tractor, fel and a box blade/skidding winch on the three point, it's a good fit. It handles my 4.5 ton crawler tractor pretty well too. I'd say 10K minimum and 18 0r 20'. In the application you describe, steel would be my preference as well.
  16. eatonpcat
    That's nice!!
  17. lukem
    Originally I had in mind a tube top utility trailer, but those are near impossible to find in 10K. I'm going to be adding plywood or metal to the sides anyway to haul mulch so I might as well just get an equipment trailer and make some side panels for the stake pockets...same difference in the end. I can load stuff on pallets this way too.
    I may cut out of work a little early today and go look at some at a local dealer.
  18. lukem
    Something followed me home..
    16+2 10K with mess/ladder ramps.
    Stephiedoll, Haftacut, Ohio and 10 others like this.
  19. Canadian border VT
    Starts thread on Tuesday; Friday has one..
    Beat Horkn truck shopping by years:cool:;)
  20. lukem
    I have been looking for a while. Just wasn't sure on size.
