Wood hauler repairs
Discussion in 'The Wood Pile' started by Pallet Pete, Mar 23, 2022.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I built this on an extreme budget 15 years ago with osb sides and after setting mostly ignored for the last 2 years at my parents house I decided to fix the old girl up. It’s coming together pretty nice so far. She will haul wood again soon.
    New lights
    Make New light brackets
    New tires and wheels
    Pack bearings
    New trailer sides
    New fenders
    New tongue box
    New chains
    New tie downs in the bed.
    B43C30D7-E208-4031-BCFA-7FEEE97637AC.jpeg 608E7551-E10C-4C67-8212-A283CC411C7B.jpeg 93C49DD4-4E72-44FA-89E5-ACDEA05D7C7C.jpeg
  2. Backwoods Savage
    Pete, it must feel darned good to have time to do these things now rather than staring through a windshield all day.
  3. Pallet Pete
    Ovid
    It’s been a blessing for sure!
  4. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Trailer's looking nice, and I see you're enjoying a cold one as well.
  5. Pallet Pete
    Ovid
    Indeed I was. The trailer and I have an understanding…. It doesn’t tip backwards and I set my beer on it. It tips backwards and I yell at it. So far I’m winning.
  6. Pallet Pete
    Ovid
  7. Redneckchevy
    Redneckchevy
    Ladysmith, Wi
    Nice work!
    I'm jealous, I wish I had a garage/shop to work in... I may actually be able to own/make something nice then :rofl: :lol:
  8. Pallet Pete
    Ovid
    A lot projects and vehicles have gone through that old garage I can't ever keep it clean... :picard:
  9. brenndatomu
    Hey, I'm convinced that the best projects come out of a cluttered up shop :thumbs:
  10. JiminyKicket
    JiminyKicket
    Seattle
    Miller Lite is my favorite for while “working”. :cheers:
  11. JiminyKicket
    JiminyKicket
    Seattle
    Also, great call on the spacing on the side walls…increased airflow means speeding up the seasoning process! :D
    Seriously though, the trailer looks great—nice work.
  12. Pallet Pete
    Ovid
    Looks like I hit a big old stop today. :picard: Because its an old popup frame that I ripped down to make into a utility trailer it has 29" fender wells. Probably why I built wooden fenders originally and I must have forgot. Talk about looking for the needle in the haystack yesh.............. :headbang:
    I might have to buy 32" and cut them down or just go cheap and make wooden fenders again. They did last 15 years! Well sort of:whistle:
  13. Pallet Pete
    Ovid
    Apparently IGA only carries Miller lite because when I went for a 12 pack of PBR they had a lot of Miller lite and everything else was out of stocko_O
  14. Pallet Pete
    Ovid
    Thanks I was going to do the front like that but I had enough scrap to make it solid. Less mud all over everything in theory.
  15. brenndatomu
    Make fenders out of a plastic barrel...then they can be (almost) any size you want.
    Could cut fender material out of a IBC tote liner too...
  16. Pallet Pete
    Ovid
    I was debating using a 55 gallon drum I’ve got laying around but it would be too narrow. I’d have to extend it. I do have IBC totes laying around that’s an interesting thought.
  17. brenndatomu
    Too narrow? You mean the barrel is not large enough diameter? I would think a "ring" cut out of a barrel could be sliced and the circle flexed open to be a good bit larger diameter...if that makes any sense. Might hafta heat the plastic some...I've found that even rigid PVC heated to 220* becomes very flexible and can be formed easily...once cooled down it stays just like you left it.
  18. Pallet Pete
    Ovid
    Its an old steel oil drum. I am debating cutting each end off of it so it keeps the ends as backers for the fender. I would have to cut each fender in half and then extend them with the remaining metal. A lot of work I don't want to get into although I might... I am going to family farm and home to see if they have any 28" fenders tonight. If they do problem solved I can weld angle on each side support to set it on for support. If they don't well no big loss I suppose.
  19. Pallet Pete
    Ovid
    BAZINGA!!! FENDERS!!
  20. buZZsaw BRAD
    Looking good there Pete. :thumbs: Cant wait to see it full of wood.
