I think I know but…
Discussion in 'Chainsaws and Power Equipment' started by jrider, Mar 19, 2022.
  1. jrider
    jrider
    I bought an older Stihl 038 magnum off a neighbor who was moving a few years ago and wouldn’t need it anymore. Today, the muffler rusted off. Aside from being ridiculously loud, is there any reason I shouldn’t/can’t run it like this?
  2. JB Sawman
    JB Sawman
    pennsylvania
    Two strokes rely on some back pressure to make them run correctly it could actually make it run lean and have less power
  3. brenndatomu
    This ^ ^ ^
    I wouldn't run it like that
  4. Chud
    Chud
    Seems like a good opportunity to open or remove that box.
  5. Ron T
    Ron T
    Northeast Ohio....Bowdil
    My thought as well.
  6. Eggshooterist
    Eggshooterist
    Erff
    I have more than one vintage saw that has what's called a stack "muffler". Its nothing more than an extension of the exhaust port with some large slits to keep things out. You can see the piston plainly through the end.
  7. jrider
    jrider
    So next question, would running a tank or two through the saw as it is cause any damage?
  8. Ron T
    Ron T
    I wouldn't risk leaning it out.
  9. brenndatomu
    This is factory?
    I'm sure the saw(s) have been jetted/tuned to be ran that way...gotta be freakin loud too! :eek:
    Horkn, T.Jeff Veal, JB Sawman and 3 others like this.
  10. Mag Craft
    No it will not hurt it and I see the diffuser is still in place. Then there is the danger of a fire hazard with it open like that.
    I would try and find another muffler for it if it were mine.
    Horkn, metalcuttr, M2theB and 6 others like this.
  11. Ron T
    Ron T
  12. Eggshooterist
    Eggshooterist
    Erff
    Not if you know how to tune it properly.
    Horkn, Nixon, T.Jeff Veal and 5 others like this.
  13. Eggshooterist
    Eggshooterist
    Erff
    Yes. Many old saws were like that.
    Horkn, Nixon, T.Jeff Veal and 4 others like this.
  14. JB Sawman
    JB Sawman
    pennsylvania
    The old saws also ran as much as 16:1 mix also the oils were not as good but it was tough to run lean with those heavy mixes and there scavenging system was not near as good but I know from racing Karts a expansion chamber gave the engines way more torque and power as opposed to just a turn out on the engine I ran mac101b engines and it made a huge difference JB
    Horkn, T.Jeff Veal and brenndatomu like this.
  15. Eggshooterist
    Eggshooterist
    Erff
    Lean air fuel ratio and lean oil to gas ratio are two different things. You can lean out an engine and ruin it on any
    oil / gas ratio. In fact as you go up in oil content, ie, 16:1 vs 32:1, you have leaned out the air / fuel ratio by displacement of some of the fuel with oil. You would then need to richen the jets to account for this. I have several saws that require 16:1 according to the manuals. They all get the same oil mix as my new saws.
  16. Eggshooterist
    Eggshooterist
    Erff
    I'll snap a picture of one of them for you.
  17. The Wood Wolverine
    What?
    Horkn, Husky Man, T.Jeff Veal and 2 others like this.
  18. Eggshooterist
    Eggshooterist
    Erff
    Definitely that lol.
  19. Eggshooterist
    Eggshooterist
    Erff
    This is my Remington SL-9 with its stack "muffler". I have a later model with a box muffler. The unit pictured is the loudest saw I own currently.
  20. Eggshooterist
    Eggshooterist
    Erff
    If anyone coming to Denny's GTG interested in running a dinosaur like this I can bring it and a couple others I have.
    Fifelaker and Horkn like this.
