Newbie questions
Discussion in 'Modern EPA Stoves and Fireplaces' started by Buck, Mar 2, 2022.
  1. Buck
    Buck
    Victoria, BC
    Hello,
    I’m a newbie and this is my first post to the forum, however I've been lurking for a while already reading and learning a lot
    My house has two fireplaces, however we only use the one in the living room but it's terribly inefficient burning a lot of wood before it starts heating the room and even longer before heat starts to come out from the louvres above the fireplace
    I never considered a wood stove, I thought it was basically the same as the current fireplace and why bother changing it since we're heating the house with an oil furnace anyway. I'm originally from South Africa, and with only two months of winter I don't have a lot of experience with heating.
    After searching the web I found this forum and discovered the benefits and decided to install an insert
    Vicky enjoying the fire, I used the old cedar shingles I removed from the shed when I replaced the roof
    We are going to have a fireplace insert installed, I ordered a Drolet 1800i and it's in the carport waiting
    I have a question
    The fireplace has a cast iron trap door, you can dump ash directly in the ash pit below
    The door to the ash pit outside the house
    Could I use it as a fresh air intake?
    I could replace the ash pit clean out door with a vent
    Where does the Drolet draw air into the stove, from below?
    The installer said I don’t need a fresh air intake with an old house like ours built in 1974, but I thought it might be good to utilize it while it’s there
    Thank you
    Buck
  2. Eric VW
    Welcome to FHC and glad you finally joined up, Buck :handshake:
    There’s plenty of debate about adding an OAK kit, some of that will be shared here.
    Then there’s the talk about dry wood, stacking with or without cover, kindling, buying saws, yadda, yadda, yadda… :yes:
    Have a good time and watch out for the real characters of FHC- they’re good for giving a ribbing and helping ya spend yer $$$
    :makeitrain"
    :salute:
  3. Buck
    Buck
    Victoria, BC
    Thank you Eric, I learned a lot already
    I removed the fireplace door last weekend, and scraped off the sealant
    You can see the trap door on the floor
    It empties into the ash pit below
    The ash pit has a ash clean-out door outside
    I thought about putting a vent in place of this door, and leaving the trap door on the floor open to get outside air. If it doesn't work I can always seal it shut outside
  4. amateur cutter
    Welcome to FHC Buck , glad to have you here! I'm not an expert on inserts by any means, but if the option is easily and inexpensively available I'm in the better to have it and not need it camp. Somebody that knows more should be along soon I would think.
  5. Backwoods Savage
    Welcome to the forum. Please do yourself a favor and no more burning of things other than firewood. Also, just forget about that cleanout; it is not needed.
    One more thing you might do is to read this: Primer on Woodburning by Backwoods Savage | Firewood Hoarders Club
  6. yooperdave
    What? I re-read through the posts and there is no mention of anything but wood being burnt. :yes:
    Welcome aboard Buck
    I hope you post more pics once the insert is installed and operating!
  7. Backwoods Savage
    That is true, but cedar shingles have likely been treated.
  8. Buck
    Buck
    Victoria, BC
    Thank you Dennis,
    The cedar shingles were untreated and very old, basically all punk wood
    The insert will only see wood
    I read your primer long ago, it was one of the first things I read here
    I even copied the Wood BTU page to a spreadsheet, my wife keep ribbing me about my "Wood spreadsheet"
  9. Buck
    Buck
    Victoria, BC
    Too late for that, I already bought a Stihl 2 in 1 File Holder after reading about it here
    It makes sharpening a lot easier
  10. Buck
    Buck
    Victoria, BC
    I bought some very dry Arbutus (Madrona)
    Vicky assisted me moving it to storage under the deck
    Stored under the deck
    Arbutus on the outside pallets, Cedar/Fir and Maple still drying on the inside
  11. Eric VW
    Vicky is Bad A! :thumbs:
    Good looking stacks!
    :handshake:
  12. Buck
    Buck
    Victoria, BC
    Just being a Jack Russell
    Thanks, it's hard work but satisfying to see your handiwork when you're done
  13. yooperdave
    True. Didn't think of that.
    But that treatment has to evaporate off after time no? Whatever.
    Would something like that damage a cat?
  14. yooperdave
    :handshake:
  15. Backwoods Savage
    Yes
    amateur cutter likes this.
  16. Backwoods Savage
    You are welcome Buck. It sounds like you are getting it all put together just fine.
  17. Backwoods Savage
    Sadly we have none of that here but those who do burn it love it. I'm sure you will too.
    You no doubt will also love that Stihl 2 in 1.
    FatBoy85 and amateur cutter like this.
