Took down a dandy red oak today
Discussion in 'The Wood Pile' started by mike bayerl, Feb 26, 2022.
  1. mike bayerl
    mike bayerl
    This majestic giant died sometime in the last year or so. Today I took it down. That's an MS661 w/ 36" bar and it was still a couple inches short of the full diameter at the base. The main trunk was completely solid and gun barrel straight. I got 2 x 12.5 foot long logs perfectly clear on all four sides, one 8 ft log with 2 knots on one side and a dandy 8' log with the crotch. Not much firewood in this one. The crown branches were dead and exploded/vaporized when they hit the ground. Great day in the woods, today. PXL_20220226_202631625.jpg PXL_20220226_213259929.jpg
    Chris F, Bill2, jrider and 37 others like this.
  2. M2theB
    M2theB
    Central Massachusetts
    right down the middle!
    Nice Job!
    looks like you cut the hinge and bore cut right behind it. Do I read that right?
    Fell cut looks to be bias cut into the bore back cut.
    Is that right?
    I can see why the bias cut would be, make sure you intercept the back cut.
    I’ve never seen that or noticed it before.
    It answers questions I’ve had.
    and leaving the hinge fat on the right pulled it right
  3. mike bayerl
    mike bayerl
    Yes, that's exactly correct, except I didn't leave the hinge fat on the right on purpose. I was shooting for an even hinge. I also had to clear out several smaller trees to create an open landing zone before I took on the big one.
  4. M2theB
    M2theB
    I saw the clear cuts. Good idea.
    Also taking note that the left side is a s#it load more cut to get to a place where the fell cut is short and sweet, even if it’s 30 degrees from the hinge.
    learning a lot from that first pic.
  5. buZZsaw BRAD
    That sure is a biggun Mike. How you liking the 661?
  6. yooperdave
    Yup, that is a dandy!
  7. mike bayerl
    mike bayerl
    I really liking it. Lot's of torque. Not as heavy as I thought it would feel, but def wouldn't want to lug it around all day.
  8. The Wood Wolverine
    Nice Mike! Bet that make a thump. Should be nice wide lumber too.
  9. mike bayerl
    mike bayerl
    Had a perfect, huge crotch 40' up. Putting that into the CSM pile.
  10. Haftacut
    Haftacut
    Rives Junction, MI
    Nice read M2theB !
  11. Dave_in_abq
    Dave_in_abq
    New Mexico
  12. Backwoods Savage
    Some nice logs there!
  13. grandgourmand
    grandgourmand
    Ontario
    Beauty. Did you use the 661 to limb?
  14. GrJfer
    GrJfer
    The Woods of Arkansas
    Wow mike bayerl that will make some sweet lumber. Great job on the felling.
  15. mike bayerl
    mike bayerl
    Heck no. I'm lucky that all my trees are within 1500' or so of my house at max. I can bring as many different saws as I want for any given jog. FWIW, on this one I really didn't need to "limb" it. There were no branches on the main trunk, 45' up to the crotch, so I just bucked out the saw logs. The crown was pretty dead and basically blew up pretty completely when it hit the ground. Of course, if anyone wants to come over and scrounge some primo oak crowns for firewood, then yes, a smaller saw would be in order.
  16. Redneckchevy
    Redneckchevy
    Ladysmith, Wi
    Thats a very nice tree there and a nice tractor!
  17. mike bayerl
    mike bayerl
    Thanks, I really maxed out the tractor skidding those logs up hill over crummy ground. That butt log is probably 1.5-2 tons.
  18. mike bayerl
    mike bayerl
    Logs stacked up off the ground and end sealed. There's actually one more 8' x 20" log on a different pile too. PXL_20220227_210146648.jpg
  19. mike bayerl
    mike bayerl
    I counted 111 growth rings on that tree. :bug:
    JimBear and The Wood Wolverine like this.
  20. Bill2
    Bill2
    New hampshire
    Logs look even more impressive now that you got them stacked up. Nice lumber there.
